Old 08-12-2016, 11:40 AM   #11
RVnut's Avatar
So who is the manufacturer of this defective door handle mechanism??..
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 08-12-2016, 02:42 PM   #12
Same thing on my 2015 GT. On our way to southern Fl. I had to crawl out the driver side window to fuel up.😃. Stopped at a camping world had us going in an hour.
Mr. G
2015 Forest River Georgetown 351DS
MrGrmpy is offline   Reply With Quote
Old 08-12-2016, 04:22 PM   #13
Vince and Charlette's Avatar
Trimark is used in my 2015 GT and in many MHs. Unfortunately, you have to take the handle apart from the inside to find out the model number.
TriMark Corporation - Latch, Handle, Linkage, Electronic, Hinge, Vehicle door hardware
2015 GT 364TSF
Vince and Charlette is offline   Reply With Quote
Old 08-12-2016, 04:37 PM   #14
I am filing a complaint with the NHSTA. I suggest everyone do the same to force a recall. Here is the link to file the complaint.
padcarroll is online now   Reply With Quote
Old 08-12-2016, 06:57 PM   #15
SS396CV's Avatar
Good to know, I carry a small screw driver kit inside, in case I have to take it apart
Looks like my Tri-Mark door latch has been replaced with a new design.
2014 Forest River Georgetown XL 378TS
SS396CV is offline   Reply With Quote
Old 08-15-2016, 04:21 PM   #16
Georgetown 30X3 Owner
Entry Door Lock Failure Update
You will be pleased (we are) to know that Forrest River, Lippert and Total Value RV are working on this issue know. We all expect an occasional failure, it is how the dealer and manufactures react that separate the good from the bad. Right now I have to tell you they have been very responsive.
DennyBevBarnes is offline   Reply With Quote
Old 08-15-2016, 05:53 PM   #17
I've been full-timing since Memorial Day and occasionally the door on my 364 TS starts to stick and you can't slam it closed anymore, you have to pull the handle a bit to get it closed.
Is this the precursor to the OP's issue?
2016 Georgetown 364TS
2005 Honda Pilot (toad)
Wife, 3 kids, dog
- Ramsey
Toad: 2005 Honda Pilot
NSA Products ReadyBrute Elite tow bar
ramseyjacob is offline   Reply With Quote
Old 08-15-2016, 06:47 PM   #18
Georgia Gets Around
djinfl's Avatar
Sticky Door
That is how ours started - a sticky door that you have to pull back in just to unlatch.
2015 Georgetown XL 369
2005 Jetta TDI
djinfl is offline   Reply With Quote
Old 08-15-2016, 06:53 PM   #19
Ramseyjacob, That's what happened to mine. I first thought the screws on the door frame needed to be tightened. But, that didn't fix it. Finally, it completely failed in the locked position. After a locksmith climbed through the driver's window and took it apart, I found that a molded plastic wedge-shaped part had broken preventing the locking mechanism from releasing the lock. TriMark overnighted me a complete new handle (at their expense). Oddly, the new one had a plastic wedge-shaped part that appeared to be exactly like the old one!
2015 GT 364TSF
Old 08-15-2016, 08:06 PM   #20
Happened to me to. Called locksmith, they said they could not help. Then called rv dealer, said,good luck.
Was able to get small daughter in small window and unlock driver window. Totally broken locked. Bought new one so I could leave for trip. Mint broke three hours before leaving. Thank God it happened before we left home
cbmerton is offline   Reply With Quote
door, lock
