Old 03-04-2015, 10:18 PM   #1
GABoy's Avatar
Entry step problem
The switch that keeps the steps out when parked and door closed has stopped working on my 2014 351. The steps just go in when door closed and out when open. The light is no longer lit on the switch when flipped on either. I'm thinking a fuse has blown. Any one know which one or where it would be just for that switch? A wiring diagram may be helpful if anyone has that too. There the kwikee steps.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 03-05-2015, 06:33 AM   #2
bubbles's Avatar
I think the fuse for the light in the switch is in the battery control box under the steps but sounds like your switch has failed or the wiring to it has an issue because just a light problem (bulb may have opened) would not cause your steps to fail as stated. JMO.
Old 03-05-2015, 09:03 AM   #3
GABoy's Avatar
I agree that just the light should not cause a problem. But I have no power at that switch anymore. Which seems that power must go through circuit when flipped on to tell steps to stay out. I'm thinking light on switch just used same power. So guess I'm on the hunt for a fuse.
Chevy Colorado Crew
Old 03-05-2015, 11:04 AM   #4
Senior Member - Retired
Entry Step Wiring Diagram
GABoy: Attached is an entry step wiring diagram I have. It is dated 2008 so it may not be exactly the same as what is installed on your MH. Good luck!
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 03-05-2015, 11:15 AM   #5
bubbles's Avatar
I don't have the Kwikee steps. Mine is the Lippert steps and my switch must be off to allow the steps to stay out with the door closed. The switch is only set to on for retracting the steps with door closed. I think Kwikee has changed their switch configuration from earlier days but my Kwikee step switch (2000 model MH) also had to be off to keep steps out with door closed.
Old 03-05-2015, 05:23 PM   #6
GABoy's Avatar
Thanks CA Fisherman! I checked the 5 amp fuse in the battery disconnect box per the diagram you posted and it was blown. Replaced and switch works to keep steps deployed with door closed and parked! The light still doesn't work on switch so assume it's blowed.
The people of this forum always make a task easier with the info they provide!
Thanks all!
Chevy Colorado Crew
Old 03-05-2015, 05:24 PM   #7
cjd10's Avatar
Is your battery connect switch on? I had my lippert steps replaced with the kwikee and the steps always go back in if the battery disconnect switch is off.
Edit.. I see you found the problem right as I posted
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is online now   Reply With Quote
Old 03-05-2015, 05:29 PM   #8
GABoy's Avatar
Yes battery disconnect switch is on as for normal usage. You are correct if disengage battery's disconnect the steps retract when you shut door as for storage.
Chevy Colorado Crew
