Old 07-23-2016, 04:52 PM   #1
External Propane Connection
My new GT335 has an external, propane connection on the shore side of the coach. It appears to be a bayonet, quick-connect snap-in fitting. It's a nice feature so we don't have to carry little propane canisters for the table top grill.
Does anyone know where to purchase a hose with the correct fitting. Everything I see at the usual websites look like screw-in connections.
DennisSimon is offline   Reply With Quote
Old 07-23-2016, 07:46 PM   #2
Here is a link to the quick connect hose I use. However, be aware that the quick connect plug on your RV is a low pressure system. Therefore, your grill needs to be unregulated. There are tons of threads on this subject - just search.
https://www.amazon.com/dp/B00CPYC9BC..._w8aLxbCWXD3A3
Darugs is offline   Reply With Quote
Old 07-24-2016, 02:56 PM   #3
You will need to remove the low pressure regulator on your barbecue and add a quick connect in it's place. Not a hard job, check out the video. video.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 07-25-2016, 09:50 AM   #4
RVnut's Avatar
We bought this grill and it came with the hose and hooked right up to our 364 fitting.. It works great for the wife and me.. Coleman NXT Voyager Grill - Coleman 2000016654 - Gas Grills - Camping World
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
propane
