01-14-2014, 09:57 PM
Kanadian Kamper
Extra vent cap on roof
Our rig is presently 1600 miles away awaiting our return for the rest of winter, so I can't do my own measurement.
I have a 2010 Georgetown 330TS and it has an extra vent cap on the roof located just above the passenger seat. (looks exactly like the black tank vent located above the washroom) I believe it is there (as a factory install) just to store some raw ended coax between there and the main television, in case of a future satellite dish roof mount.
I'm playing around with a modification idea I have, to mount a particular antennae in this location and would need to run the antennae lead from the exterior to the interior at this point.
Does anyone know what the thickness of the roof would be in this area?
Ken and Terry
01-15-2014, 06:04 AM
Can't answer as to roof thickness but I did notice that vent cap near the front of the MH while I was up there. Wondered what it was for.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
01-15-2014, 07:46 AM
Same here. Was wondering if its similar to an attic vent.
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
01-15-2014, 08:36 AM
It's a dummy vent location for your sat prewire.
01-15-2014, 05:40 PM
Does it have a power awning. If so it could be the wind sensor. On my 2009 350ts the wind sensor looks like a vent cap on the passenger side near the awning.
01-15-2014, 06:26 PM
Which one is it? I was dead set on the pre-wire for the sat version. Which BTW, does it have the wires already in place?
We have a power awning, but was unaware of any wind sensor. Makes sense though.
Glad we found this artifact and waiting for more input.
01-15-2014, 06:38 PM
The wind sensor control is located in one of the compartments near the awning. It will be secured to the top of the compartment. And it also has a remote. Here are some pictures.
01-15-2014, 06:42 PM
Oh, you are making me jealous. I wish we had one of those. We didn't get that option.
01-15-2014, 06:54 PM
They might put the cap in the roof for the option. It is ok but you can't tip the awning or tie it down and it can't be adjusted. Good in one way not so good in other ways.
01-15-2014, 08:12 PM
DC power white and red as well as a coax to your switch box.
01-16-2014, 01:01 PM
Kanadian Kamper
Iggy.......... I sorta remember looking inside the cap a very long time ago, and although I do recall seeing some coax, there may very well have been the two other wires you mentioned.......makes sense.
I'll be at our rig in a few weeks and will double check, but I'm planning on attaching my Sirius antennae on top of the vent cover and running the wire inside to the dash location of the radio for the antennae to have optimum reception.
Either way..............I'm going in!!!!!!!!
Ken and Terry
01-16-2014, 08:50 PM
Where did you find the antenna with a long enough wire to reach your radio?
George & Jerri
06 GT 340 TSSE
USMC
01-17-2014, 11:08 AM
I have sirus sat radio that I ordered for the motorhome and the system cost 19. bucks already have subscription on our car. The antenna they supply is magnetic however I had a dealer install the wire he drilled a hole and ran the wire down the side of the windshield behind the molding and then under the dash and plugs into the sat radio. Then use an epoxy to secure the antenna and dicor to fill the small hole. Works great.
Andrew & Donna Reyes 2012 Georgetown 378XL 2015 Ford Taurus & Our Baby Dachshund Cammie
01-17-2014, 12:26 PM
Kanadian Kamper
Jergeod..........The antennae from the Sirius vehicle kit (see link) comes with enough wire to reach from the roof vent to the location where my actual Sirius radio is positioned on my dash.
As part of the kit.......it is normally long enough to go from the rear roof of a car, down and around the rear window trim, into the interior of the car and run all the way to the front dash area for a more "hidden" installation.
For my RV........I already mounted a lightweight metal bracket to the OEM vent cover for the magnetic antennae (a very strong magnet I might add) to attach to. Then I'll run the wire inside the vent stack, through the roof, and hide it on the inside of the RV down the inside trim of the front windshield, under the dash to the location of the actual radio.
Ken and Terry
01-17-2014, 11:35 PM
What link?
George & Jerri
06 GT 340 TSSE
USMC
01-18-2014, 09:47 AM
Kanadian Kamper
Jergeod...........
Sorry about forgetting the link. BTW.........up here in Canada, for some reason, all the Radio Shack Stores changed their name to The Source a few years back. They seem to carry most/all the same things but I'm attaching a link to Radio Shack for your benefit seeing as you live in Central New York state.
SIRIUS-XM SADV2 SIRIUS Universal Plug and Play Vehicle : Car A/V accessories | RadioShack.com
Ken and Terry
04-27-2014, 07:56 AM
Miked11272. You can tie the awning down if you turn the windsensor off. Just use you remote control and hold the bottom 2buttons for 5 seconds. To turn it back on hold the top 2 buttons for 5seconds. You will know it is off if you open the awning and have to continue to hold the open button until it is fully open. On 2008 370 Georgetown my wind sensor is at the end of the arm right next to the motor. Happy camping to all.
Sent from my SCH-I535 using Forest River Forums mobile app
04-27-2014, 01:34 PM
Kanadian Kamper
Just a closing follow-up..........
We just returned from Florida after trying to wait out Mother Nature..........she's still trying.
As far as the installation I described, I installed the Sirius antennae on my home made metal bracket mounted on top of the vent cap located overhead of the passenger seat. There was enough antennae lead to run from drilling through the roof at this location (and properly sealed) then running the lead over to the overhead storage shelf above the passenger location, down inside the plastic corner windshield post to the dash, then along the under side of the passenger dash over to the center radio area and connected to the Sirius docking station for the radio.
On our trip back from Florida to Canada, not ONE loss of signal for the Satellite radio. Full signal strength the entire way.
Ken and Terry
06-05-2014, 06:05 PM
Thanks, I did try this and was able to tie the awning down worked great. Thanks again
06-05-2014, 06:33 PM
Would be very cautious about tying down the awning with supporting the tube for fear of bending an arm.
