Forest River Forums
Sunline User Photos
Old 04-28-2010, 06:24 PM   #1
Factory Chassis A/C not working
When I picked up my 2011 Georgetown 350, the dealer had noted that the factory chassis A/C was not working. Compressor would not engage.
They were unable to locate the problem and said that I would need to take to Ford. Took the RV to Ford today and they have not been able to locate the problem either. They asked me for a wiring diagram of how Forest River hooked up the A/C between the coach and the chassis. Of course I don't have that wiring diagram. Trying to get from Forest River.
Anyone else ever experience something similar or does anyone have an A/C wiring diagram for a late model 350? Freon levels are good, pressure switch works fine, etc. Ford said they checked all of the normal things and they are stumped. They want the wiring diagram to hopefully pin-point the problem before tearing everything apart.
blightle is offline   Reply With Quote
Old 04-28-2010, 07:44 PM   #2
NWJeeper's Avatar
From the literature that came with our rig the A/C is by a 3rd party supplier, not Ford, not FR. FR installs it once the shell is put together. Ours had no wiring diagram.
Ed & Wendy
www.nwjeepn.com
Old 04-28-2010, 08:11 PM   #3
Thank you for the reply. I agree that the A/C blower, duct work, etc. are from a 3rd party but I also understand that the A/C compressor on the engine and part of the wiring harnesses are from Ford. Not sure about the freon canister. My understanding is that Forest River ties the third party components into the Ford compressor and existing wiring harness. I did a little looking and Ford has labels on all of the wires in the factory harness so that the RV manufacturer knows what to hook up where. Guess they did not get it quite right on mine. Also my Ford fuse block in the engine compartment contains an A/C relay, clutch fuse and an clutch diode so it appears to be a combination of two systems.
Old 04-28-2010, 08:37 PM   #4
NWJeeper's Avatar
That would make sense and they (Ford dealer) should be at least able to determine if the compressor is good or not by wiring +12volts directly to the clutch input on the front of the compressor to see if it engages, that would elimenate some of the possibilities. They should be able to get it figured out for you.
Ed & Wendy
www.nwjeepn.com
Old 04-28-2010, 09:33 PM   #5
Moderator
Don't have a wiring diagram, but I can tell you on 90% of vehicles how it works. AC switch on control panel operates the AC relay, sends 12 volts, through the diode,to the AC clutch on the compressor.
Oops, the 12 volts also goes through the low pressure and high pressure cutout switches. Also there is no freon canister, that is a drier or accumulator. You short the high and low switches to verify their operation. I would be looking at another dealer maybe. Any auto tech that knows anything about AC should know these things, especially a newer R134a system, as they are all the same from the major 3 manufacturers, and most foreign cars. I used to check all these before I ever needed or wanted a diagram. NWJEEPER is right, hook 12 volts to the compressor and watch for smoke. At least it will tell if there is enough freon to get cold. I also don't understand how they know freon levels are good or that the pressure switches work if they can't get to the compressor to engage. You can't tell freon level by static pressure, system must be running. Good Luck.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 04-28-2010, 09:36 PM   #6
ronhanson's Avatar
It could be something as simple as a wire or harness not being hooked up during assembly. I have a hard time believing Ford is at fault here since their QC is light years ahead of Forest Rivers or the AC vendor, but you're going to have to go through some work trying to figure out what is wrong and who is responsible. It won't be easy since you have 3 parties involved at this point. Ultimately, Forest River is responsible for their integrated product so I would get the factory involved if you haven't already. Dealers are mostly worthless if they cant turn a screw. The factory will green light any costs so you're not on the hook for anything.
Contact:
Mike Burns
Forest River Inc.
Warranty - Retail Motorized
Phone - 574-206-7603
Fax - 574-206-2484
Email - mburns@forestriverinc.com
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 04-29-2010, 09:33 AM   #7
This morning, Forest River sent me a wiring diagram for the 3rd party Evans Tempcon A/C system that was installed in my Georgetown. Thought others may find the diagram useful so I am uploading it here (thanks to NWJeeper telling me how to upload a file).
Will respond back once the Ford dealer determines the problem in case anyone else ever has a similar issue. Thanks for all of the replys. This is great forum!
File Type: pdf EVANSTYPICAL ELECTRONIC ROTARY WIRING DIAGRAM.pdf (290.6 KB, 48 views)
Old 04-29-2010, 10:54 AM   #8
NWJeeper's Avatar
Thanks for the diagram. I have saved it to my "Georgetown Documents" file on my computer for later reference. I have managed to find .PDF files for almost all the documentation for our rig and have it all stored on the computer.
Ed & Wendy
www.nwjeepn.com
Old 04-29-2010, 12:30 PM   #9
cfsoistman's Avatar
If I'm betting on the solution to the problem. I'll take bad ground for $200. FR seems to rely on self tapping screws into the frame. They used an aluminum trim oval head type for the ground to my headlights with an oversized terminal round connector and a big washer. The aluminum oxidized, lost contact and I had no headlights. They also don't remove any paint where the terminal connector contacted the frame so the threads were the only source of contact. I drilled out the hole, wire wheeled off the paint and bolted the connector to the frame and then coated with battery terminal protectant. I'm eager to hear what they find.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-29-2010, 09:30 PM   #10
So Ford figured out the problem with the A/C. Cfsoistman, you were half correct. Turns out that the Power Control Module (PCM) which is apparently the computer that controls most of the engine functions also controls the ground to the A/C clutch relay. The service tech said that the PCM was not controlling the ground properly. Apparently was not something a software flash would fix so a new PCM is on its way from the factory. Since it is a 2011 chassis, no one has this part in stock yet. Ford dealer did not even have a part number in the system and had to call Ford Engineering in Detroit to get a part number.
I have to hand it to the Ford service guys, I would have never found that one on my own. At least this was a Ford issue so there is no charge to me and no need for me to seek reimbursement from FR.
a/c, air conditioner
Close [X]
