06-04-2011, 02:33 PM
Factory work problems
I have a 2004 ,370 XL bought new.Have had problems with windshield and roof leaks from day one.Has been back to the farctory six times from 2005 to 2010 ,still having roof leaks.I knew of several of you that had the same problems in the past with the 370 XL. Does any of you still have these problems or did the factory get them fixed?
06-05-2011, 02:28 PM
Sorry to hear of your problems. I feel very fortunate I only had one leak problem and that was at the slide-out at the head of the bed. The floor got wet any time it rained. The tech at Chesaco RV found that the holes at the bottom that allow water to drip outside had been sealed almost closed. He opened the holes up some and we've never had another leak since. My only major problem was when the rear broke after 9200 miles. That was a Ford problem which they took care of it 100% including the towing to the repair facility.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
06-06-2011, 11:08 AM
I had those problems to but this is a lot differant. My coach was one of several that was assembled out of square from the factory. The windshield has broke or come out four times from 2005 to 2008.The windshield gasket has pulled away from the frount cap twice . The factory cut the rear cap and the frount lose and moved the roof in a efford to squar it up. When they did this it screwed up all three slides. All three slides have been reworked and late modle gaskets installed. This didn't help.They installed a plate in the frount top in frount of the cabnets to hold the cap from moving,this was first done by a 2004 owner in Calf. then the factory tried it . After they did this mod. they had to replaced the cabnets and tv with the ones in a 2008 modle. After they did this they had to repaint the coach,for the second time. They put crown molding inside to hide the fact the roof had be moved. This is when the leaks started.Left frount above the driver seat leaked when you were driving.Wouldn't leak seting still the people at two dealerships couldn't make it leak on the lot.I made a tape of it leaking at 60 MPH over the drver's head.The factory cut some of the covered on the side to top and added a brace to hold the roof still.Then it leaked on the right side above the window.Davismotorhome fount the where the factory had replced the awning,the screw at the top runing through the seal was in wrong and it was leaking in the side wall there.How it is leaking above the door and window.It leaks inside the wall bad enough to get it runing through screws and geting the trim wet around the door top wet. Mississippi doesn't have a lenon law on R.V.s so I am srewed there. You think I am stuck. How Dan Evens at Forest River tells me the warranty is up they will not work on it.
06-06-2011, 11:23 AM
I'd contact John Armstrong with all of your facts. He's the one to speak with about long time warranty issues. I've worked with John before and he has always been fair. I hope he can help you in some way.
jarmstrong@forestriverinc.com
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
06-22-2011, 07:58 PM
Talk to factory
Dan Evans is the manger of warranty ,Mr. Armstrong works for him. I don't have any complaints of how they handle your problems but if you have a bad bad problem and you live in a state where they don't have a lemon law, they will patch and patch give you all these little upgrades to keep you passafied ,or they hope it will .My problem with the windshield comeing out and cracking was just the start. For six years how I have working with Mr. Evans about this and other problems caused by them trying to alter the coach to put a bandaid on the on the problem.They have added braces,they have tried to move the roof,they have shifted the rear cap in a efford to squair the body up. This caused many leaks and still have leaks . How Mr. Evans says they can't do anymore.Take to a shop and they will help them find the problem. I called Forestriver main office and asked for Mr. Liegl. They said they would have someone call me back this was Tuesday,this morning they called .A man that works under Liegl . After a long talk he said he would talk to Mr Evans and call me back Thursday afternoon. I told him I was disapointed in Forestriver in the way they had handled this.I have had two other Forestriver trailers before this motorhome with no problems that I couldn't take care of myself,after all I have worked on all kinds of equipment for 47 years now and have be working for Fedex the last 23 years as a maintenance tech. I would like to just get the coach fixed. Mississippi doesn't have a lemon law for RV's .If you live in a state with no lemon law I would thank twice before I buy a Georgetown unless you have a lot of money you can have it fix or loss money and get another Motorhome. I hope he does call back Thursday but I don't expect good news,they know the laws.
07-14-2011, 02:29 PM
Update , After getting the brush off from Dan Evans and his bunch ,I called Pete Lighl office. I told the girl what my problem was. Later that next day a rep. for Lighl's office called. I talked to him for the best part of a hour. He had to talk to Evans and would get back to me the next afternoon after 4:30 centeral time. After the three had talked this is what they came up with. I would have to sign a letter of releace and they would have a Co. go over the coach to see if it meet RV standards and they would fix .How after six tmes to the factory they are going to fix it , if the Co. of their chiose said it was out of standards (who is paying this Co.)???? I told him what he was saying was they know what the problem is but they don't want to fix it or make it right. He said his people said it was poor mainteance . It has been to the factory six times and what they are looking at is there own peoples work or the lack of QC by Evans and all conserned. I have had the 370 xl new in 2004 ,seven years,and it has been to the factory six times. Now the hold right side from the door to the frount is roten,the mirrow is loose becuase wood has rotted out be hind the fiberglass. Above the right window they sealed the inside with black RTV to keep the water from the inside out of sight. I told him I work on aircraft for Fedex and they would fire me if I worked like that. Maybe they should take a closer look at what their Pro's did. I sent him pictures of all the work or the lack of ,to him. Lets see what he has to say.
07-14-2011, 03:24 PM
You need an attorney
07-14-2011, 05:25 PM
You really need an attorney. How good is your inisurance? lol.
2008 Rockwood 8281ss
2006 Dodge Ram Mega Cab Hemi
Reese 15k Slider
07-14-2011, 08:03 PM
There needs to be a Lemon law for RVs or an Independent Company that investigates these types of problems on behalf of both the Customer and the Manufacturer. There's nothing more frustrating than having paid for a product that doesn't provide the satisfaction that should be there from day one. Everyone makes mistakes but after the numerous attempts of the factory to fix the problem they should have just replaced your coach. I really hope they come to their senses and realize their reputation will suffer more than replacing a messed up coach.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
07-14-2011, 08:17 PM
Lemon law or no lemon law, if they are not willing to replace your coach on their own there ought to be some type of consumer protection law on the books that would apply to your case and force them to do so. Get a lawyer and find out.
What you have gone through is ridiculous and uncalled for. I can't believe that FR is treating you this way. They are a much better company than that.
They tried to fix the coach and failed. They should replace it rather than kicking you to the curb!
Good luck. I hope things work out for you.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 312 |
| 22 members and 290 guests |
| 12vdzl, 1l243, brookside, ChiefGeek, Fester Carbunkel, flynmoose, Greene, honda1, HondoPatrick, House97, klkdp, Mountainmanbob, MrMeyer, Namchief, nrcamp, onthelake, photog, Rebel702, Rsgtivr6, shooted, sprayking, toclark491 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
