Old 09-08-2014, 11:41 PM   #1
Fellow RVrs.
With my 2004 GT 375 XL, I recently pulled my boat, the trailer had a short on the left side and now have a fuse to the rear light that is blown and I can't find the fuses. I Looked through the panel in the engine compartment, and under the steering column. None were blown.
My upper tail light is out, bulb is fine. This is the same side the trailer light wiring had shorted.
Does anyone out there know of another location of fuses I can check to see if a fuse is blown.
I greatly appreciate your insight.
Ron Grice
Rongrice is offline   Reply With Quote
Old 09-09-2014, 08:20 PM   #2
jergeod's Avatar
First check the light socket with a meter or light probe to make sure it is dead, if that is the only light that is out you can bet it is not a fuse.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 09-10-2014, 12:45 AM   #3
Thanks, I will check it in the morning.
