Old 06-18-2011, 09:30 PM   #1
Filling fresh water tank
Can anyone tell me if there is a way to add water to the fresh water tank on the 2011 378ts without a preasureized hose we do a fair amount of dry camping and we always leave with full tank of water but sometimes need to add water from containers we carry from home. I could add to the tank from the winterizing section on our last A class which was a coachman.
CanadianRVER is offline   Reply With Quote
Old 06-19-2011, 08:33 AM   #2
ronhanson's Avatar
You could use the pump to suck from the container. There is a hose tee'd off the inlet for sucking antifree out of jugs when winterizing. It wont fill the tank though.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 06-19-2011, 09:22 AM   #3
That is a great idea and at least you could always use this in an emergency...can't imagine the heat I would get if we ran out of water...if you dry camp alot might be a good idea to buy a couple of those plastic gas cans and carry a them full of water...
polkatronron is offline   Reply With Quote
Old 06-20-2011, 09:01 AM   #4
LOL I do carry extra water cans. In my last coach I coould suck from the winterize inlet direct to the holding tank. not this one :<(
Old 06-20-2011, 09:55 AM   #5
Wanna Be Camper
SaskCampers's Avatar
Get one of these and a bit of pipe and a few fittings that PA has as well, find a 12v source and off you go.
http://www.princessauto.com/all-seas...ny”-pump
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 06-20-2011, 11:10 AM   #6
Herk7769's Avatar
Here is a very low tech method that has served us well.
We buy a 6 gallon blue water jug (WITH HANDLE) at home depot.
Remove the top and carefully cut out the "puncture" hole.
Using an exacto type blade make a tiny air hole in the cap.
(to speed things up)
Insert a long vinyl tube and reattach to the jug.
Invert and use gravity to transfer the water.
To be honest we have since bought a manual "bilge pump" that fits those neck openings to pump it right into the tank.
ID:	6434   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-20-2011, 11:37 AM   #7
Thanks for the info guys. I think I lie the transfer pump idea. Small price to pay to avoid DW running out of water. :>)
Old 06-21-2011, 09:49 PM   #8
If a tee and a valve are added to the line on the output side of the pump the suction line for the antifreeze could be used to fill the tank.
Mike
MikeA is offline   Reply With Quote
Old 06-21-2011, 11:26 PM   #9
ken0042's Avatar
I bought one of these containers at Wal-Mart years ago for tent camping. I haven't tried recently; but I'm sure the spout also allows for a hose to connect to it.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 06-22-2011, 02:14 AM   #10
They make the transfer pumps in 110 volt also
Fourn3833 is offline   Reply With Quote
