Old 02-23-2016, 03:35 PM   #1
Film Protector Front of Motorhome
I have a 2010 Georgetown 350TS motorhome and the film protector on the front has turned colors and can't remove bugs and road grime. I've done my best to keep clean and protected. Any suggestions? Makes motorhome ugly.
ID:	100237   Click image for larger version
ID:	100238   Click image for larger version
ID:	100239   Click image for larger version
ID:	100240   Click image for larger version
garytenorsinger is offline   Reply With Quote
Old 02-23-2016, 09:10 PM   #2
ernest917's Avatar
Same stuff with the mask on mine..... Only solution - remove it... A hand-held steamer, couple of hours and something to remove left over adhesive.... (Or hire it done at a cost of abt a grand which should include replacing with new...)
It will only get worse.... Trust me - I know....
ernest917 is offline   Reply With Quote
Old 02-23-2016, 10:24 PM   #3
Does it have to be steamer? How about hair dryer?
Old 02-23-2016, 10:31 PM   #4
ernest917's Avatar
Not enough heat...... Will take twice as long and not come off as easily.... Heat gun is just the opposite - too much heat....
Old 02-24-2016, 06:07 AM   #5
Remove it....I removed mine without a heat source other than parking it in the sun and just taking my time
Carmen is offline   Reply With Quote
Old 02-24-2016, 07:23 AM   #6
I saw this exact same problem on another RV at a campground a few months ago. The discoloration is actually mold growing under the film. The guy had to remove it using a plastic razor blade so as to not damage the paint.
Good luck in getting it off.
Thanks,
rkulbok
(Ron & Karin)
2015 Georgetown 328TS
Full time since October 2015
rkulbok is offline   Reply With Quote
Old 02-24-2016, 08:29 AM   #7
Do they still use the film on the new motorhomes?
Old 02-24-2016, 09:59 AM   #8
RVnut's Avatar
our new 2016 has it
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 02-24-2016, 11:13 AM   #9
I also have it on my 2015 and I am already noticing some dis-coloraration by the door lock.
Thanks,
rkulbok
(Ron & Karin)
Old 02-24-2016, 01:04 PM   #10
If it is the same company (Diamond Shield) I wouldn't trust it. Aside from the mold issue growing underneath the film, many people have had issues with it pulling the paint off when they tried to remove it. One of the problems comes from the paint on the motorhome not being fully cured before the film was installed
Old 02-24-2016, 01:09 PM   #11
7 Year Class A RV'er
Have you checked your paperwork on the film? I think some of it may have a lifetime warranty, not sure. I know they will come to your house to fix it.
2015 Legacy SR340 360RB
Old 02-24-2016, 01:30 PM   #12
RVnut's Avatar
Since there are all these problems with the stuff why does Forest River insist on installing it??
364 Georgetown 2016
in Montana
Old 02-24-2016, 01:55 PM   #13
This is true, but only to the original owner, it was not transferrable
Old 02-24-2016, 05:18 PM   #14
I am the original owner. Where would I find this warranty?
Old 02-24-2016, 05:37 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
I seen one at Goshen than 2-3 guys working two days to replace the Diamond Shield on the Berkshire. That was a Forest River fix. Good luck.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 02-24-2016, 06:04 PM   #16
Diamond shield is trash mine is coming off in spots to hard to remove not worth
The amount they charge to install mine is a 2014 coachman
Dkplace is offline   Reply With Quote
Old 02-24-2016, 06:21 PM   #17
Search the Internet for "Diamond Shield" and contact them directly, they will have one of their authorized dealers replace or fix it free. Ours came with a lifetime warranty.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 02-24-2016, 10:31 PM   #18
Coach Guard - 574-296-1466 is the company that Forest River had do the Diamond Shield when mine was done....not sure if they have changed or not, but as of last year Coach Guard was still operating
Old 02-24-2016, 10:32 PM   #19
Bubbamace's Avatar
Since everyone is having a bad time with Diamond Shield, I thought I would express my positive experience with it. We have a 2013 Georgetown XL and haven't had a problem with it other than protecting the front end and side of our motor home. The bugs come right off of it and rocks don't seem to penetrate it. We camp off road frequently and Diamond Shield has saved the automotive paint. I would have it put on my motor home again should the opportunity arise again.
Bubbamace is offline   Reply With Quote
Old 02-26-2016, 07:12 AM   #20
Wolverine 1945's Avatar
I am betting Carmen nailed the problem here !!!
Wolverine 1945 is offline   Reply With Quote
motorhome
