Old 11-26-2013, 05:21 PM   #1
BillMFl's Avatar
Finally pulled anode from water heater
Was surprised to see it was totally gone in just two years of light use. Lots of white scale particles.
BillMFl is offline   Reply With Quote
Old 11-26-2013, 05:46 PM   #2
Herk7769's Avatar
That is why in needs inspection every year.
The longevity all depends on the water quality.
Water with high levels of iron or sulphates will accelerate deterioration.
HAM CALLSIGN - KC3FFW
Old 11-26-2013, 05:52 PM   #3
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
That's why it's necessary to pull it every year and inspect it. For us snowbirds in areas where you need to winterize, it's no big deal because the anode has to be pulled so the tank can be drained. In warmer areas I suspect that the anode is going to wear out faster because it's in contact with water year around whereas in the colder climates there are several months that the tank is drained and the anode is not subject to wear.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-26-2013, 06:18 PM   #4
intercept's Avatar
Make sure you flush the tank out. Even when we winterize it each year with only 6 months of use you get a hugh amount of white scale from the tank. CW has a small diameter short hose to stick into the drain hole to flush it out. It works well.
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
Old 11-26-2013, 06:25 PM   #5
Ours was pretty nasty and we just got our coach a few months back.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 11-26-2013, 07:01 PM   #6
Lloydg's Avatar
How nasty is nasty? The anode should look nasty, but it's supposed to and means it's working. Until it wears down to about the diameter of a pencil, you should be ok. As noted earlier, that's why it's important when you winterize or inspect the anode that you flush the tank to get rid of all the particles.
Old 11-26-2013, 07:03 PM   #7
bikendan's Avatar
we have really good water out here, so i didn't have to replace mine for 6 years.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-26-2013, 07:49 PM   #8
Ford Idaho's Avatar
I don't have one to replace.
One reason I run a water filter.....
Old 11-26-2013, 08:00 PM   #9
Then you don't have a Suburban with an anode.
The filter will not stop an anode from disintegrating.
Old 11-26-2013, 08:15 PM   #10
Ford Idaho's Avatar
Ya I know, but the filter kleeeens "stuff" out and that keeps my little alloy tank Kleeeeeen...
anode, heater, led, water, water heater
