Old 06-09-2018, 06:05 PM   #1
Iggy's Avatar
Finding 12 volt DC Power in dash
Hi All
I'm adding a USB charging station on the dash of my Georgetown for my GPS and Tire Monitor screen. The station only puts out 2.1 amps at 5volts.
Well I was wondering if anyone has found a spare circuit from the fuse panel under dash that would be easy to tap into for this USB station.
I know I can go from the engine battery but thought maybe someone else found an extra circuit at the fuse panel that I can gain access easily.
Notice I said easily.
Here is a picture of the USB power station.
I picked it up at RVupgrades.com for $22
2012 Georgetown XL - 378TS 63K + miles
Old 06-09-2018, 06:08 PM   #2
Tap into the radio hot line. That way it will power off with the radio
donniedu is offline   Reply With Quote
Old 06-09-2018, 06:33 PM   #3
Iggy's Avatar
I was just looking at that fuse F16 which is a 20amp and feeds a lot.
Radio, Cigarette lighter, front power shade. Thanks but will still keep looking.
I see that the panel under the dash has empty locations for fuses
Anyone know if they are actually usable?
The reason I ask is because some don't have metal contacts in them.
I do not have the motorhome readily available now.
Old 06-18-2018, 10:20 AM   #4
I ran my wires straight to the battery. That way I have power 24/7 and don't have to worry about something going wrong after piggybacking onto something else's power supply.
1st Time Rv'er
2017 Forest River Georgetown 364TS
2018 1,949 Miles Traveled 26 Nights Camped
2017 4,978 Miles - 38 Nights
2016 2,248 Miles - 16 Nights
TexasChris is offline   Reply With Quote
Old 06-18-2018, 10:50 AM   #5
Iggy's Avatar
Thank you.
That seems to be the most reliable way to do it.
Old 06-18-2018, 05:06 PM   #6
bubbles's Avatar
My existing accessory socket has an inline fuse and is powered continuously (not dependent on ignition ON). I tapped (paralled) into that feed ahead of that fuse with an inline fuse (lower amp) for my added accessory socket. I run an oxygenator from the existing and TPMS from added.
Old 06-18-2018, 06:04 PM   #7
Usually Confused Member
emm-dee's Avatar
You can get these on Amazon. Allows connecting the original fuse and a separate one of the same or different capacity.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 06-19-2018, 01:31 PM   #8
Iggy's Avatar
Yes this is what I'm considering doing.
Just need to find a used fuse that is not over worked with amps.
I think the size of these fuses are ATC regular?
I don't have my rig close by so I don't remember the p[physical fuse size.
12 volt, power
