Old 10-19-2014, 11:08 AM   #1
Iggy's Avatar
Finding power source for.....
I need your help in finding the power source of the toggle switches on this control panel.
The specific ones I'm looking for is the power to the 3 blue toggle switches.
I lost all power to the one blue toggle that controls the steps.
Steps work fine as this toggle controls the ground wire which works fine.
I just lost positive + power to the terminal on the switch that powers the light.
All other blue lights work fine and would have thought they all come from a common source but it seems not.
I have checked all fuse in the bedroom as well as the power distribution under the steps and all check out fine. Any I do not imagine they come from any of the panels in the engine or under the drivers side dash as all those are Ford stuff.
Any suggestions?
The reason I ask is because I have 3 LED toggles I plan to replace these with. These old one put out way too much heat when it so I picked up 3 blue led ones on EBay for a few bucks.
Here is a link to EBay and what I purchased if anyone is interested. LINK
Old 10-19-2014, 09:46 PM   #2
43D18's Avatar
Can't help with the power supply but I can say that every one of those little lights behind the toggles has burned out in our first year. Two were replaced and have burned out again. No problems losing power to steps or entry light so far.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 10-19-2014, 09:47 PM   #3
ramair's Avatar
could be just the light bulb burnt out and not anything wrong. I had one go out.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 10-19-2014, 10:22 PM   #4
Iggy's Avatar
Yes the bulb is burnt out in the switch and that is why I'm replacing them all with LED switches.
I just wondered if anyone knew where the power was distributed from to these lights. I will figure it out when I replace them on Tuesday next week.
Old 10-20-2014, 06:40 PM   #5
Funny you posted this because this last Sunday the blue light on my step toggle switch stopped working. Step work fine though! Will be waiting for a reply about power as well. Also would like to know the source of the LED switches
DennyH is offline   Reply With Quote
Old 10-20-2014, 06:49 PM   #6
Iggy's Avatar
The lights are powered from this 5 amp fuse in the power distribution panel.
I know because I blew it today when I goofed on the wiring and made a direct short.
If your light went out it just may be the bulb. If the other switches light next to it then it is the bulb and not the fuse.
power
