First trip in the Georgetown 31b3
Just got back from our maiden voyage. It was about 900 miles round trip from Philadelphia to Columbus, OH for a race. I was pleasantly surprised at the power it had. I normally pull the trailer with a 2500 duramax, so I was excepting it to be a little sluggish with power but nope, it pulled right up the long hills with no problems (despite the high rpms, I knew it was coming). Along the flats i could keep it right at 65-70mph with no problems. I did do the CHF what a difference that made, I did it because of the reviews on this site.
The bad's, got to Ohio and could put the slide out after leveling. Code said house batteries were dead or needed replacing. Code 3 once then 4 after a while. Generator was on the whole time out to Ohio, We ran the heat for the kids (32 degrees both ways). The slide worked in the driveway before we left while plugged in, but I tried it again when I got home to clean it and it still wouldn't go out. Don't know where the house batteries are and its pouring out so I don't feel like digging into this now.
Second thing water is leaking in top right hand corner of coach. Comes down the wall to the top of the window, and also out from above shade.
Last thing so far is the camera on the right side keeps coming on (without turn signal) and staying on or just not working. Something must be telling it to turn on. Loose wire somewhere.
All in all it was a good trip and a lot less money then staying in a Hotel. Thank you all for the info this site keeps me informed and helps with a lot of troubleshooting.
2017 Georgetown 31B3
2017 Chevy Silverado 2500 Duramax
