11-24-2011, 02:59 PM
Floor and porch lights
My floor lights and porch light quit working and have searched for fuse a can not find one. No power at switch, jumped power to switch and lights work. Went through fuses in back of Georgetown and under steps. I even tried fuses under dash no luck. It's a 2005 Georgetown. Any ideas would be great help!
11-24-2011, 07:48 PM
A line slideouts
All depending on how you jumped power to them the switches tend to go bad and my need replaced? I can look into it further when I get back to work on Monday I just need to no what model you have so I can look the wire print up for it?
11-24-2011, 08:11 PM
I unplugged the power from the steps and plugged it in to the other two switches. On the model I am not sure my title just say Georgetown. Where could I find it?
11-26-2011, 07:44 AM
Check the weight list usually in one of the kitchen cabinets. It may state the model number there. How long is your coach? The length is usually the first two numbers. Ours is 37 foot and the model number is 370TS. Triple slide.
http://www.crrvc.com/usedmh/usedmh04/usedmh04.htm
Is it this floorplan? 359
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
11-26-2011, 10:25 AM
It's real close to that floor plan. But without The third slide. And it is 35 feet in length. I will go out to the storage yard and check on the stickers.
11-29-2011, 03:54 PM
It may be a 346 ds
11-30-2011, 05:07 PM
I know of three places on my coach where there are fuses so you might check these three places for a blown fuse. Assuming that there is no voltage at the input of the switch.
Fuses in the power panel where the AC breakers are
Fuses in the power center that the house batteries connect to. (have to take the plate off to see them)
And there are some wires on mine that run directly from the stuff in the step well to the positive pole of the batteries and they have inline fuse holders in the wire (this is the first place I would check).
2008 Georgetown SE 350DS BunkHouse
12-07-2011, 11:07 PM
Does anyone think it would be a problem if I run a 2 wires from the switch that has power for the steps and give power to the other switches for floor and outside lights. I have tried every fuse I can find and nothing. What does everyone think?
12-08-2011, 05:07 AM
Moderator
Did you ever get back to Chuck with the model info? He works at FR I believe and would be your best bet to try and fix it properly first.
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
12-08-2011, 07:10 AM
ME
On our model a additional fuse is wired "in line" and was located behind the actual switch panel. I am on a mobile device so not sure on your floor plan (cannot open it) OR pull out your bottom drawer next to those switches to see if a fuse is wired in there. That's where mine was! Sort of like a early Easter egg hunt.......
2008 Georgetown 350TS
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 307 |
| 21 members and 286 guests |
| 12vdzl, 1l243, bama gail, brookside, ChiefGeek, Fester Carbunkel, Greene, HondoPatrick, House97, klkdp, Mountainmanbob, MrMeyer, Namchief, nrcamp, onthelake, photog, Rebel702, Rsgtivr6, shooted, sprayking, toclark491 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
