Old 01-01-2011, 04:42 PM   #1
floor, walls and ceiling
Hi There...Has anyone had a problem with the floor squeaking, the wall coverings coming away from the wall, and the ceiling bowing??? We traded in our Newmar and bought a 2011 Georgetown and we have these problems. Are we alone or does anyone else have problems like this?
phillip kent is offline   Reply With Quote
Old 01-01-2011, 04:55 PM   #2
Pete
gartonhl's Avatar
see my posting regarding the ceiling. You'll need do do a search for:
"Sagging ceiling headliners" on this forum.
See if it helps.
What model is your Georgetown, and when did you purchase your unit?
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 01-01-2011, 05:09 PM   #3
I have a 2009 Georgetown 374. Just lately the floor has started squeaking in the bedroom right by the bathroom door. Hope this is not a sign of things to come.
peskin is offline   Reply With Quote
Old 01-01-2011, 11:53 PM   #4
I have a 2008 Georgetown 374. Floor does squeak up front in living area, and had to get one wall repaired that was coming apart where the thermostat and command console is located.
Ggantilla is offline   Reply With Quote
Old 01-02-2011, 07:58 AM   #5
I have a 2008 Georgetown 338SE. The floor near the slideout and the kitchen area squeaks. It seems the underlayment flexes as though it wasn't fastened down properly. I tried using a special screw that you snap off after you run it into the floorboard; but it didn't help. Just living with the problem hoping it doesn't get worse.
Crossfire is offline   Reply With Quote
Old 01-02-2011, 10:37 AM   #6
For your floor I have seen cushion flooring shrinking in the cold weather. A while ago In one of our highrise building when it was new all the empty units that were not sold and the temperature was kept at 50* got damaged. Many floors were short by aprx one quarter inch at the baseboard. All the other units occupied were not affected. I read the the beaufloor cushion floor is not affected by the cold. Not sure if my new 2011 rockwood has the beaufloor. It has the wood look vinyl flooring and the tuscan interieur.
capucine is offline   Reply With Quote
Old 03-04-2011, 05:33 PM   #7
08 340 TS .. main slide. (couch & dinnette)
Viewing the slide, looking at the couch, just behind the drivers seat ... floor and that wall came apart....busted loose all the way.
Tech. stated he spent 3-4 hours ... drilled for three large wood screws and refastened floor & wall. Covered with strip.
We paid out of pocket 420 bucks.
We had troubles with this slide since new. (( Even the ram, has been replaced)
Good luck.
Mac
08 340 TS Georgetown SE
07 GL18007
www.centexpgr.org
mac wing is offline   Reply With Quote
Old 03-04-2011, 06:45 PM   #8
tncruiser's Avatar
what about your warranty for these problems
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 03-06-2011, 01:32 PM   #9
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
No, our coach is rock solid. We've been living in it since Sept. and love it.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
