Originally Posted by Rongrice
Has anyone else had a problem with the tank flush just backing up with pressure? Mine seems to be blocked with something, can only imagine what, and am not sure how to clean it.
Does anyone have any good suggestions of what to use to clean out the tanks?
Ron
I hate to say this and there are some other threads around here somewhere on this problem, but some people have reported in the past on such blockage problems on brand-new units.
After jumping through all the hoops it sometimes came to the point where the tank had to be completely disconnected and dropped to find the problem. I remember one poster who said that when the hole for the toilet was drilled out that the "disc" of plywood had dropped into the tank. It was probably close to quitting time and the worker who made that mistake conveniently forgot to fish the piece out of the tank. Well, that piece of wood blocked the drain and the whole tank wound up full of sludge and it was a nightmare of a mess.
I REALLY hope that isn't your problem, but on a brand new unit you should not have enough of a build-up to cause an almost complete blockage. The only way that might happen in normal usage is if you kept the valve open all the time. That's a no-no...you need to have a good amount of liquid in the tank at all times until it is drained. (And personally, I always add several gallons of water afterwards when the TT is not in use.)
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
