Old 01-11-2013, 11:28 AM   #1
Ford Chassis Questions
Just FYI - I talked to an Engineer from the Ford Motorhome Division this morning about the F53 chassis. Here's some of the things he told me:
1. The suspension mod of moving the attachment points on the front and rear sway bars is recommended by Ford, but it will offer a more firm ride while adding some increased stability. The sway bars are designed to handle either hole location. Ford installs on the outer holes purely for ride comfort. Modifying to the inner holes will not impact the chassis warranty.
2. Ford Motorhome division phone # is: 800-444-3311
3. Ford recommends to all MH manufacturers to have 40% (front) and 60% (rear) on the UVW ratio. He told me that many consumers are getting their coaches weighed to find that the front axle is only getting 30% or less of the total UVW. To correct this some manufacturers are offering to install air bag helpers to level out the load. He suggest that if the MH manufacturers aren't going to do it, than the owners should if the ratio is not close. 40% on the front axle will help with tracking and stability.
Hope some may find this info useful.
MGOBlue is offline   Reply With Quote
Old 01-11-2013, 11:40 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Thanks for sharing the info. I haven't done the suspension modification but have added air springs all around. So far I've found it really helps with the rocking from passing trucks. I always have more pressure in the rear air springs than the front by about 15lbs.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 01-11-2013, 03:19 PM   #3
Iggy's Avatar
Great information MGOBlue especially that you spoke with a FORD REP.
I think many of us need to get our motorhomes weighed.
I have done the swaybar mod and running 100 psi in all my tires.
I would like to hear about weight distribution on other who have their motorhomes weighed at a scale.
I think it is worth the few bucks or whatever it costs.
Old 01-11-2013, 03:41 PM   #4
I also talked to the National Rep at Cat Scale. For a MH, they charge $10 to give you weight by axle. It would be $10 for just MH or MH and toad. They have a website to location a scale (CAT Scale). They are mostly at truck stops. I'm getting mine weighed as soon as the spring hits.
Old 01-11-2013, 06:47 PM   #5
Graduate Member
RoadTrip's Avatar
excellent tip!
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-15-2013, 01:00 PM   #6
copsuno's Avatar
Only one question, reading the conversation, is it listed correctly or did Ford not recommend the relocation of the sway bar? Just something in the wording indicates maybe the word, not, is omitted. Just asking.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 01-15-2013, 02:17 PM   #7
Iggy's Avatar
Old 01-15-2013, 07:18 PM   #8
I know that the iRV forum thread states that Ford DOES NOT recommend it. That's why I talked to Ford Motorhome group directly and they DO recommend it now.
Old 01-15-2013, 07:56 PM   #9
Iggy's Avatar
QUOTE
Call
Old 01-15-2013, 10:26 PM   #10
What is the torque of the attached bolt? Thanks
trell is offline   Reply With Quote
