Old 07-11-2010, 02:20 PM   #1
CLASS "A" Senior Member
cfsoistman's Avatar
Found 2 wires under my 370TS
While under my Georgetown today checking things out I came across 2 wires hanging down next the water heater compartment. One White and one Red w/Black Stripe with no wire nuts or anything on the end. They looked like they were just snipped off. When I got out and opened the Propane compartment door I saw that these wire run behind a metal shiled that the gas pipe is connected to. I tested them and they was no reading. I decided to turn on the Curbside compartment lights and Bingo there was current. I guess at one time they planned to put a light in the Propane area and changed their minds. For the time being I'm just going to screw a wire nut on them but I'd like to know if anyone with a Georgetown does have a light in that compartment? I'm thinking about adding one with a switch inside the water pump area so if I ever need light out there I'll have it.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-11-2010, 04:04 PM   #2
NWJeeper's Avatar
No light in my propane compartment although there is one under the steps for the batteries.
Ed & Wendy
www.nwjeepn.com
Old 07-11-2010, 05:19 PM   #3
tmmar's Avatar
I would assume that there is no light in the propane tank compartment because in the event there is a leak and if you went to investigate and turned on the light, the spark created by turning the switch on could ignite the propane. The results could be disastrous.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-11-2010, 05:52 PM   #4
cfsoistman's Avatar
That was my thought also but bare wires just hanging sure didn't make much sense. The only way these wires are live is when I turn on the switch inside the motorhome.
Oh well, just wondering if anyone had a light.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-20-2010, 08:59 PM   #5
I Have a 2010 Gergetown and it does not appear to have lights in any compatments. I guess this is how they meet their price points goal in ways that the purchaser will not notice till after the purchase has finalized. I find a lot of little things that I would take for granted have been omited in the process of skimping. I am sure I will one day have the coach upgraded to the point that it should have been from the factory but by then I'll be at the Itasca Meridian price point. LOL
Lloyd
starburst2 is offline   Reply With Quote
Old 08-20-2010, 11:41 PM   #6
NWJeeper's Avatar
Lloyd
Are you positive you don't have compartment lights? They don't come on automatically. Inside the entry door there should be a bunch of switches. there may be a panel with just two switches above the rest, they are to turn on the driver/passenger side compartment lights.
Ed & Wendy
www.nwjeepn.com
Old 08-21-2010, 12:08 AM   #7
I'll check again and let you know. Thanks for the info.
Lloyd
Old 09-25-2010, 11:26 PM   #8
Hi NW Jeeper
I was over at the repair shop and had a look into the compartments. There are no light s in any of them. Seems strange. Another mod I'll have to undertake. Wow, that makes for quite a few at the top of my priority list.
Lloyd
Old 09-27-2010, 07:18 AM   #9
Hi NW Jeeper
Lloyd
I bought stick up tap on 3 LED lights for all my compartments on E-Bay. $2 per light $24 total. If I leave them on the only battery I drain is the one in the light. They work great and provide enought light for each compartment.
LED Peel n Stick on Tap Light Adhesive As on Seen TV !! - eBay (item 350398206091 end time Oct-26-10 18:09:02 PDT)
Hope this helps.
2010 373DS
Master Tow with 2008 Nissan Altima
bresdogsr is offline   Reply With Quote
Old 09-27-2010, 10:00 AM   #10
ronhanson's Avatar
My 09 350TS only came with 1 light in the large compartment next to the door. Cost cutting on Forest River's part for sure. I used the LED lights in the other compartments like bresdogsr.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
