Old 04-26-2012, 02:32 PM   #41
VinceU's Avatar
Wow, looks like Manvel may have found a solution if not a improvement! The cap in Iggys note is down tight, see orange tabs just above oring.
Old 04-26-2012, 02:52 PM   #42
SEAYALL's Avatar
Originally Posted by manvel View Post
Pictures
interesting .. thank you very much for the picture ...
SEAYALL is offline   Reply With Quote
Old 04-26-2012, 02:54 PM   #43
SEAYALL's Avatar
then it would appear to be a differnt cap than mine.. i thought his looked like it sat up alittle higher.. thanks
Old 04-26-2012, 05:04 PM   #44
manvel is offline   Reply With Quote
Old 04-26-2012, 06:47 PM   #45
SEAYALL's Avatar
that's what its going to take, believe your on to something ... i know i'm wearing you out .. so the o-ring is just setting there, i'll take a trip to home depot see what i can come up with, thanks ..
Old 04-26-2012, 08:35 PM   #46
I push the o-ring down , did not leak,need to put tape around pipe above o-ring so that it fit tight against tank.
Old 04-26-2012, 09:35 PM   #47
VinceU's Avatar
I also have a 2012 Georgetown 378. Never had the serious leak but have had some dripping. I think the worst case is when the leveling jacks are all retracted at the same time (auto mode). Thats lots of volume quickly. If 2" isn't enough, surely a short secured hose with the vent and filter at the top would do it. That's often how tanks are vented to prevent "burping". Good find sir.
Old 04-30-2012, 04:53 PM   #48
VinceU's Avatar
Measured tank from Lippert (Parker Hannifin) to hose connections today with a dial caliper. Seems hose threads are .062" -1/16" larger in diameter and pitch appears different. Hose is GHT standard 11.5 Threads per inch. The cap for hyd tank seems like 12TPI. Bottom line is male hose is larger than the tank opeing and may split it forcing a hose thread in. The cap inserts easily into female hose fittings, very close to size for size and would "strip" easily. Cannot ID the tank threads, oh yes they are sharp v shaped while hose is rounded. It will work for short term but may be bigger headache than the existing proplem. Do not maintain talk full- it won't blow out nearly as bad.
Old 04-30-2012, 04:58 PM   #49
Can a surge tank be used with a hose connected to it and inserted deep enough into the surge tank to allow syphoning back into the main tank?
Old 04-30-2012, 05:00 PM   #50
Warrior's Avatar
Originally Posted by Harleydriven View Post
great video, i have the same problem on my 2012, georgetown 378. i've looked an looked at reservoir an the manifold i don't see where its coming from , must be cap also, theres what appears to be a breather, L shaped pointing down i wondered about that, but drip continues, please post if you find something out , thaks you
123d q
Wayne & June Bowers Camp Mutts Bo & Baby
2011 F250 Lariat 4X4 SCSB 6.7 Power Stroke
50 Gallon Titan Fuel Tank
2011 Flagstaff 8528RLWS 5th Wheel
Reese Sidewinder Hitch 2002 Road Star Warrior
SouthWest Florida FROG
Warrior is offline   Reply With Quote
