Old 08-02-2016, 02:00 PM   #11
Flybob's Avatar
Originally Posted by 360true View Post
Tried the procedural fix. Seemed to work, but overnight started leaking again, filling the tank and dripping overflow. My temp solution is to turn off city water and use the fresh tank, refilling as necessary until I can get the pump replaced under extended warranty.
Turn off city water
Turn off water pump if on.
Turn on any faucet wait 1 min
Turn on water pump
let water run 1 min
Turn off faucet
turn off water pump
Wait for water pump to quit running
Turn on city water
This reseats the check valve in the water pump. Do not run the water pump when connected to city water.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-02-2016, 04:58 PM   #12
360true's Avatar
Trying that now. Will let y'all know. Thanks for all the suggestions!
360true is offline   Reply With Quote
Old 08-02-2016, 09:35 PM   #13
DouglasReid's Avatar
Instead of replacing the pump which is expensive, or replacing the check valve in the pump which is a pain in the a__, or even a ball valve which requires you to take some action (opening it up) when you want to use the tank water, why not spend $10.00 for a 1-way check valve that will fit inline in the pex tubing.
They are available at Home Depot, Lowes or any other home improvement store, or any plumbing supply house, not to mention Amazon, eBay and other online sellers.
Fast, Easy and Cheap Permanent solution.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 08-03-2016, 11:48 AM   #14
I have the same problem with mine. For me the solution is to simply turn off the pumps when hooked up to city supply. No issues like for me.
5nomads is offline   Reply With Quote
Old 08-03-2016, 12:12 PM   #15
Flybob's Avatar
Did it work?
TST Tire Monitors
2 65W solar panels
Old 08-03-2016, 12:22 PM   #16
Unless you are in a situation where the city water supply pressure is tremendously low (think 8-10 campers hooked to one line at a rally) your pump SHOULD ALWAYS BE OFF when hooked to city water.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 08-04-2016, 05:58 AM   #17
360true's Avatar
Flybob.... Worked thanks! Followed your steps exactly. So far so good.
5nomads... Note the issue occurred for me with the pump off and hooked up to city.
Old 08-04-2016, 06:13 AM   #18
Iggy's Avatar
X2
2012 Georgetown XL - 378TS
tank
