Old 10-23-2014, 10:13 AM   #1
bigben's Avatar
Fresh Water Fill on Georgetown 351
As I stated before, new to Class A and I was filling my fresh water tanks to sanitize with diluted bleach solution. Attached the hose to the fresh water tank side to fill. Gauge inside consistently reading almost empty and then water started to flow out from hose directly alongside the low level drains.
First any ideas on why the gauge on the panel continued to read E?
Next, why was the water flowing out so fast? Is this the location of the overflow? And did I start the water siphoning action by overfilling the tanks and then causing the water to continue to flow?
Anyway, advice please.
Georgetown 351, 2015.
bigben is offline   Reply With Quote
Old 10-23-2014, 11:06 AM   #2
Average Joe
MrJoe's Avatar
Is there a chance the tank drain valve is open?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 10-23-2014, 01:16 PM   #3
bend302's Avatar
You may have built up some internal pressure if the overflow can't let the water out as fast as you put it in. I have read about some folks that fill their tanks slowly to assure they don't "overfill". That said, I have never had that problem. I just turn off the water as soon as I see overflow happening. As for siphoning, it usually stops as soon as the water level drops below the vent.
As to the indicator light: The indicator might have a broken wire not connecting the sensors. These light units are notoriously poor. I can see my water level by looking in the water pump compartment.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 10-23-2014, 01:30 PM   #4
bigben's Avatar
Thanks for the responses. Can you tell me where the fresh water drain is located? Sounds like a goofy question but I cannot locate it in the manual. Thanks again.
US Army - Retired and loving it with our Georgetown 351DS and now our Thor Challenger 37TB.
Old 10-23-2014, 01:36 PM   #5
RudysWorld's Avatar
On my 350 there are 3 hoses in the same location as the low point drain. One is the low point drain with a srew in plug, one is the fresh water tank drain with a screw in plug and one is the fresh water overflow which does not have a screw in plug. Hope that helps. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
fresh water, georgetown, water
