Old 05-10-2011, 12:57 PM   #1
Enjoying LIFE
Fresh water pump -- location
I know this is crazy but I can't find the fresh water pump on my 2008 FR Georgetown 373DS. I also need to know ifthere is a fuse or something else that would casue the pump to stop working. Thank you for any help.
Gene Ross is offline   Reply With Quote
Old 05-11-2011, 06:57 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
In my case there is a black panel above the propane tank with a 4 inch access screw type cap. The water pump is inside there as well as an in-line fuse holder. The panel can be removed but it is sealed with silicone to keep the heat in there and prevent any freezing.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-11-2011, 09:54 AM   #3
Pete
gartonhl's Avatar
On the 2010 378TS the water pump is located on the passenger side, second storage bay from the back. Ditto above, it's behind the black plastice cover. Our black cover is not sealed with silicone; it has srews on edges and corner that you need to remove to gain access. See 15 amp inline fuse in secound pic.
ID:	5741   Click image for larger version
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 05-11-2011, 09:28 PM   #4
kenandterry's Avatar
Same layout and compartment location on the 2010 330TS as the 378TS. I was just checking mine out earlier today.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
