Old 07-19-2016, 01:18 PM   #11
Tailwind's Avatar
One of the first things I did to mine when I got it was to remove the black covers. Mostly, I was curious as to what was behind them. Glad I did, it provided access to quite a bit of stuff, such as the water pump, bypass valves, antifreeze intake hose, etc. I can also now see the fresh water tank and hoses.
2012 F-250
Flagstaff 8528IKWS
Tailwind is offline   Reply With Quote
Old 07-19-2016, 04:01 PM   #12
Send a message via Skype™ to Falcon35
I have taken mine of many times but I put it back on as I think it gives the pump a little bit of protection when it gets close to a freezing temperature. The Arctic pack doesn't cover the pump.
Falcon35 is offline   Reply With Quote
Old 07-19-2016, 07:17 PM   #13
Cornelius's Avatar
I removed the plastic cover hiding the tank to install the valve, and for the same reasons Tailwind mentioned. It's nice to be able to visually check the water level in the tank.
If there is freezing weather, I put a small utility lamp with a 60 watt bulb in the compartment. A second lamp is used in the other compartment with the water filter. The heat from the bulbs keeps the plumbing above freezing. It's just like the old Kenner Easy Bake Oven....
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
fresh water, tank, water
