Old 04-22-2016, 07:39 PM   #1
Fresh water tank drain
Have a new [to me] 08 Georgetown 338s now parked in my driveway. Going over the water systems and can not find the valve for draining the on-board fresh water tank. Any help greatly appreciated....Bob
margesdiamond is offline   Reply With Quote
Old 04-23-2016, 09:20 AM   #2
RVnut's Avatar
I dont know about yours but our FR is just a plastic plug behind the rear wheel along side the over flow.. I removed the plug and installed a hand valve for ease of emptying.. You just have to get on your back and crawl around underneath the beast till you see it
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 04-23-2016, 10:04 AM   #3
I have a different model but mine is located at the low point hot and cold water drain lines.
My tank drain has a black plastic screw on cap only. No valve.
Old 04-27-2016, 06:53 AM   #4
chrisbailey13's Avatar
+1
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
Old 04-27-2016, 08:51 AM   #5
RVnut's Avatar
Well I took off the black cap and put a hand valve so it is much easier to drain the tank since we dont leave water in our tank between trips.. Much easier to turn valve.. I still have to remove caps on low point drains when winterizing.. Just a upgrade that is handy
364 Georgetown 2016
in Montana
drain, fresh water, tank, water, water tank
