05-02-2014, 04:34 PM
Fresh Water Tank Drain Valves
I had valves on my old TT instead of the end caps that come stock with the RV. They were white and screwed on the end of the drain pipes.
I'd like to install them in this coach but can't seem to find them. Could someone please post a link or a part number. I would have thought they were pretty common. Thanks in advance.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
05-02-2014, 09:04 PM
Pipe threads can be 3/8", 1/2" or 3/4" in the range you are talking. Most likely the drain tubing is 1/2" NPT or "National Pipe Thread" OD of the fittings would be about 5/8", dimension not size.
05-02-2014, 10:38 PM
Everything used in RVs is 1/2" PECS. You should be able to find pecs in most plumbing supply houses, Lowes & HD carry some, not sure if pecs uses standard thread sizes though.
George & Jerri
06 GT 340 TSSE
USMC
05-03-2014, 06:05 AM
Originally Posted by Iggy
Yup, like that but male threads in one end and smooth no threads on the other.
05-03-2014, 06:11 AM
I finally found a picture of what I had, but still not a place to get one. I may have to go to an RV place to see if they have them.
05-03-2014, 09:12 AM
05-05-2014, 02:38 AM
that's what I did was take black drain plug out and went to cw with my black plug and matched it up, it was 1/2 inch npt. And got shut off, used Teflon tape and worked good, no crawling under Neath any more. Pete.
05-05-2014, 06:08 AM
Yeah, they are a must have. Our coach has four drain lines, but the one used the most is the fresh water tank one. Like you said, no more crawling under and getting wet.
05-05-2014, 11:04 AM
Exactly what I need. Thanks
