Is there a way to drain the fresh water tank? I got a lot of calcium when I was in FL last year and the line to the toilet is always getting clogged with the calcium deposits. This year before I go back I want to find a filter that connects between the hose and the water source.
I believe your low point drain and fresh water holding tank drains are together along with the fresh water overflow drain. The low point and fresh water drains should have caps installed. Remove the caps and both will drain.
Yes you can drain the fresh water tank.
Find you low point drain and open it.
See my pictures.
