Old 04-28-2012, 10:48 PM   #11
Herk7769's Avatar
Originally Posted by Hybrid21SS View Post
What if you have well water at home and all the parks you visit? Is this step critical?
The problem with well water is two fold. One it has silt in it which will clog your filters over time. Two the lack of chlorine will allow the build up of bacteria and algae also over time.
Monthly sensitization is most likely in your future.
Lou and Laura - Shopping for a Camping Buddy
2008 GMC Sierra 30000HD Crewcab SB Allison Duramax
HAM CALLSIGN - KC3FFW
Old 04-28-2012, 11:17 PM   #12
bend302's Avatar
Herk has the best answer...Put some bleach into an EMPTY hose connected to your fresh water fill. Connect hose to spigot. Put water in tank. That's how I do it and it is simple...
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 04-29-2012, 01:07 AM   #13
Duh. How about if you hook it to the city water fill? I don't know if that goes through the water filter or not.
Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 04-29-2012, 03:37 AM   #14
Herk7769's Avatar
Forrest
It does, but there is a check valve in the water pump that will prevent the water pump and everything before it from being sanitized. You won't sanitize your fresh water tank; all the hoses including the fresh water tank vent line; and the pump pre-filter basket.
Old 04-29-2012, 07:59 AM   #15
acadianbob's Avatar
Originally Posted by herk7769 View Post
Then drain and flush with chlorinated city water. Done.
I had to flush mine twice to get all of the bleach smell out of it . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 04-30-2012, 08:49 AM   #16
lochsa's Avatar
Curious, where do you typically do the sanitation at? For those of you who live in the suburbs, are you doing this in your driveway? Also, how do you know how often this needs to be performed? Is there an smell that you're looking for? My concern is my MH will be sitting in 90+ degrees for a month at a time. I know what my swimming pool would look like if I left it sitting there for this long.... As a precaution, I plan to take drinking water with us on our trips.
lochsa is offline   Reply With Quote
Old 04-30-2012, 09:11 AM   #17
Herk7769's Avatar
I do mine in the driveway. First of all it does not take a lot of bleach to do a sanitization. You probably use more bleach when you do your wash.
Algae does not grow in the dark. If your tank is covered you won't have that worry, but bacteria can and will grow in the dark. Chlorine will degrade with sunlight and evaporation and neither is a problem in a closed system like your RV. Once you have chlorinated water in your tank again, it should be no more dangerous than the water in your house pipes.
The problem comes when you drain it for winterization. Empty pipes and tanks are breeding grounds for bacteria and need to be sanitized before use. RV (non-toxic) antifreeze is great at keeping stuff from freezing but not so great at preventing bacteria growth. After dewinterizing you must sanitize to have a healthy fresh water system.
If you use well water in your fresh water system, there is obviously more chance for bacteria growth and I believe the suggestion is a monthly sanitization to keep it safe. (I would use bottled water for drinking in this case anyway).
As an aside, I carry distilled water for the Tassimo coffee maker as it triples the life of the internal filter.
Old 04-30-2012, 09:42 AM   #18
As a side note, after running bleach through ours, I run about a half-cup of baking soda (mixed with a gallon of water first) through to eliminate the bleach smell. Works like a charm!
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 04-30-2012, 03:41 PM   #19
annamarie's Avatar
Good idea! Thanks.
David & Annamarie(Fatty & Harley)
2011 Rockwood windjammer(3065)
annamarie is offline   Reply With Quote
