04-28-2012, 01:34 PM
Fresh Water Tank Sanitization
Hi Everyone,
I have a 2010 337 and want to sanitize my fresh water tank. I read in the "Manual" that I need to make a mixture of clorox and water and pour into the tank. My question is how and where do I pour it into the tank. I don't see anyplace where to pour it.
Thanks for your help.
Richard Farrell
2010 Georgetown 337
2005 Jeep Grand Cherokee
04-28-2012, 02:42 PM
Originally Posted by RLFarrell
Hi Everyone,
Good question on how and where you can add the bleach.. Humm
If I had to do it I think this is how.
If you check the compartment oustside with the water tankk and pump I believe you will find a white hose that looks like it is coming off the top of the tank and it had a threaded plug at the end of it.
I would take that and open it and raise it above the tank and use a funnel to add the bleach. Then go to the other side and fill the tank full of water. I will check and see if I have a picture onf mine.
Could someone verify if I'm correct or ?
04-28-2012, 03:11 PM
Is this how you fill the fresh tank in the Georgetown?
Why not just pour 1/2 cup of Clorox bleach (without any soap in it BTW) into an empty water hose; hook it up to the MH where you normally do and turn on the faucet. Let the tank fill till it vents (you can disconnect the hose here) then turn on the pump. When you get Clorox smell at each faucet shut the pumps off and wait 24 hours.
Then drain and flush with chlorinated city water. Done.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-28-2012, 03:21 PM
Sherlock
I had the same question when setting up my 2012 GT 378TS. I took a small hose, poured in the mixture using a funnel & then finished filling the tank with city water. After several hours I drained the tank & flushed with fresh water. You should do this when new & then at least once a year thereafter.
2021 Forester 3051
2017 Ford Focus Toad
04-28-2012, 04:45 PM
Sounds like a simple solution. Great!
04-28-2012, 07:04 PM
What if you have well water at home and all the parks you visit? Is this step critical?
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
04-28-2012, 07:15 PM
FW tank
Iggy
The plugged hose is actually an alternate suction to the water pump. Its used mostly for adding anti-freeze while winterizing. The three way valve in the pic will allow it to change from tank suct to your bucket or jug.
04-28-2012, 08:32 PM
Originally Posted by VinceU
Iggy
Ohhhh. I will have to remember that this coming winter here in Arizona.
Did you know it actuallyget as low as 45 degrees here in the winter.
04-28-2012, 08:36 PM
How about removing the water filter, filling the empty bowl with the mixture, then adding water through the city water fill? All water entering the mh goes through the water filter (according to the manual).
Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
04-28-2012, 09:46 PM
Forrest
This will not sanitize the holding tank.
04-28-2012, 09:48 PM
The problem with well water is two fold. One it has silt in it which will clog your filters over time. Two the lack of chlorine will allow the build up of bacteria and algae also over time.
Monthly sensitization is most likely in your future.
04-28-2012, 10:17 PM
Herk has the best answer...Put some bleach into an EMPTY hose connected to your fresh water fill. Connect hose to spigot. Put water in tank. That's how I do it and it is simple...
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
04-29-2012, 12:07 AM
Duh. How about if you hook it to the city water fill? I don't know if that goes through the water filter or not.
Forrest
Happy Trails
fbconsults
(Forrest and Donna)
04-29-2012, 02:37 AM
Forrest
It does, but there is a check valve in the water pump that will prevent the water pump and everything before it from being sanitized. You won't sanitize your fresh water tank; all the hoses including the fresh water tank vent line; and the pump pre-filter basket.
04-29-2012, 06:59 AM
I had to flush mine twice to get all of the bleach smell out of it . . .
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
04-30-2012, 07:49 AM
Curious, where do you typically do the sanitation at? For those of you who live in the suburbs, are you doing this in your driveway? Also, how do you know how often this needs to be performed? Is there an smell that you're looking for? My concern is my MH will be sitting in 90+ degrees for a month at a time. I know what my swimming pool would look like if I left it sitting there for this long.... As a precaution, I plan to take drinking water with us on our trips.
04-30-2012, 08:11 AM
I do mine in the driveway. First of all it does not take a lot of bleach to do a sanitization. You probably use more bleach when you do your wash.
Algae does not grow in the dark. If your tank is covered you won't have that worry, but bacteria can and will grow in the dark. Chlorine will degrade with sunlight and evaporation and neither is a problem in a closed system like your RV. Once you have chlorinated water in your tank again, it should be no more dangerous than the water in your house pipes.
The problem comes when you drain it for winterization. Empty pipes and tanks are breeding grounds for bacteria and need to be sanitized before use. RV (non-toxic) antifreeze is great at keeping stuff from freezing but not so great at preventing bacteria growth. After dewinterizing you must sanitize to have a healthy fresh water system.
If you use well water in your fresh water system, there is obviously more chance for bacteria growth and I believe the suggestion is a monthly sanitization to keep it safe. (I would use bottled water for drinking in this case anyway).
As an aside, I carry distilled water for the Tassimo coffee maker as it triples the life of the internal filter.
04-30-2012, 08:42 AM
As a side note, after running bleach through ours, I run about a half-cup of baking soda (mixed with a gallon of water first) through to eliminate the bleach smell. Works like a charm!
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
04-30-2012, 02:41 PM
Good idea! Thanks.
David & Annamarie(Fatty & Harley)
2011 Rockwood windjammer(3065)
