I'm having an issue filling my fresh water tank. I have a 2015 350XL. I attach my fill hose to the fresh water fill and nothing happens. I've filled the tank in the past. Any thoughts?
When I recently had this problem it was the back flow vavel sticking shut. The valve is located where you connect the hose. I was able to disconnect it just behind the hose connection and remove three screws that hold it to the coach.
Charlie and Joan Monckton
3309 S. All Hallows Ave.
Wichita, Kansas
Before replacing it try removing the screened washer and press the white pin in the center. It may only be stuck. If it continues to stick then replace it.
