Old 05-21-2016, 02:28 PM   #1
Freshwater drain on 364
Ok....other than low point drain assume I'm missing the obvious...where is freshwater drain please? Haven't used it much yet and just testing out pumps.
JLud is offline   Reply With Quote
Old 05-21-2016, 02:34 PM   #2
Krazymace's Avatar
Mine are right behind my passenger side rear tires. Gotta lay on the ground to see them.
Krazymace is offline   Reply With Quote
Old 05-21-2016, 02:48 PM   #3
So the low point drains are the freshwater drain in this unit? My TT TH had a fresh dump valve and low point drains so wanted to be sure.
Old 05-21-2016, 05:47 PM   #4
RVnut's Avatar
Our new 364 has three low point drains, one overflow drain and a fresh water tank drain all behind the passenger rear tire and all have grey plugs.. I installed a hand valve on the tank drain
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 05-21-2016, 06:10 PM   #5
RVnut's Avatar
Attached a picture of ours
Name:	tank drain 001.jpg
364 Georgetown 2016
in Montana
Old 05-21-2016, 06:48 PM   #6
Haha just took a pic myself thanks nut...which one is fresh tank then?
Old 05-22-2016, 10:24 PM   #7
Assumed it was the one next to vent and uncapped overflow...but just a trickle when I emptied is what is causing me to doubt....guess just didn't have much water in there...thanks.
Old 05-23-2016, 09:47 AM   #8
RVnut's Avatar
I will say ours is the one closest to the overflow but as you can see it could be glued in another way also.. Best bet is take the plug out you think it is and try to fill the tank.. If it starts running out shortly after then you have the right one
364 Georgetown 2016
in Montana
Old 05-31-2016, 09:50 PM   #9
Tried to fill again and had it leaking out of one of the hoses. Mine match your picture above, but one of the lines next to the bent was not capped. Opened the bay above it to look and low and behold a cap waiting for me to use. Put that on and no problem, just wanted to be sure that isn't blocking an overflow or something.
To be clear it now looks like the picture earlier, I'm good to go right? It took a lot longer than I thought it would to fill it... Must really slow the water down coming in.
Old 06-01-2016, 09:22 AM   #10
RVnut's Avatar
you are good to go.. I will say with the pressure regulator it takes a while to fill
364 Georgetown 2016
in Montana
drain, water
