Old 02-10-2016, 11:47 AM   #1
tilap's Avatar
Fridge
Anybody know where we can shut off the water going to the residential fridge in a 377XL?
Denis, Forest river Georgetown XL 377 2015, towing a 2014 Ford Explorer XL
tilap is offline   Reply With Quote
Old 02-10-2016, 12:44 PM   #2
I believe that there is a water line under the sink behind the garbage can and there is a push button valve that shuts of the water line.
dirievi is offline   Reply With Quote
Old 02-10-2016, 01:10 PM   #3
tilap's Avatar
I was
Told that, but no not there. The fridge is on the opposite side of the sink so I would assume the the valve is somewhere on the same
Side but again Thea MH builders sometime you wonder what they think of when they design them.
Old 02-10-2016, 01:17 PM   #4
Sbryant's Avatar
On my 2014 GT 360 XL, my shutoff valve for the refrig is in the same bay as my water/sewer hookup - BEHIND the Black Skirt partition
Sbryant is offline   Reply With Quote
Old 02-10-2016, 01:20 PM   #5
tilap's Avatar
I took the black skirt off and no joy there either. I think the only place I didn't look is the engine compartment
Old 02-10-2016, 03:40 PM   #6
DarrenK's Avatar
On my 328TS, it's in the pantry to the right of the fridge. Pull out the bottom drawer, and there is a white screw on hand access. Remove that, and there is a push-pull valve like mentioned previously. Took me forever to find too...
DarrenK is offline   Reply With Quote
Old 02-10-2016, 03:47 PM   #7
tilap's Avatar
No pantry n the 377 on either side of the fridge.
Old 02-10-2016, 07:13 PM   #8
WhoDoMan
On my 377xl 2014 the valve (push button type valve) was in the storage compartment below the refrig. If you look in that compartment there maybe a cable tray or stapled cover there. Mine was wrapped in a kind of rinno-plastic cover that looks like a wire protector, so don't be confused. Mine had a leak at the valve so that is how I found it. Good luck.
whoDoMan is offline   Reply With Quote
Old 02-10-2016, 07:29 PM   #9
tilap's Avatar
Whodoman I cant f....believe it. Your right, it is there I would have never found it. The only difference is mine is at the end of a 1/2 blue water line that change for a 1/4 white line with a turn nob kind of valve. Thanks appreciate it. I looked there before but when I saw the black plastic rinno I thought was an electric cable. Thanks again your my hero for the day.
Old 02-10-2016, 07:42 PM   #10
WhoDoMan
No problem...this forum is the best. Everybody helps where they can!!!
fridge
