Old 10-31-2013, 09:08 AM   #1
Fridge Light
My bulb blew in the fridge when a water bottle fell against it. Replaced with a new bulb which is 12V 10W same as what originally was there but size is slightly fatter and a tad longer. Replacement bulb does not work. Bought another set from a auto parts store, it doesn't work either. I would find it difficult to believe that a fallen water bottle could loosen anything to not make the light work.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 10-31-2013, 09:15 AM   #2
Hi Sherman, On our gtown 337, the fridge light has a short in it, have to fiddle with it to come on. The next time I open the door its out. Will fix it this winter. FYI.
martin73 is offline   Reply With Quote
Old 10-31-2013, 09:20 AM   #3
Thanks Martin, where would you suggest looking for a short, behind the light itself and is it removable?
sherman12
Old 10-31-2013, 10:28 AM   #4
We had the same frig light on /off problem in our 2011 g'town 360DS. Putting in a new bulb didn't help. Went back to dealer/service. They had to pull the frig out to get to the problem to fix it.
Doree and Neal,
2018 Cardinal 3850 RL Estate
ADK-RVer is offline   Reply With Quote
Old 10-31-2013, 10:31 AM   #5
I hope the short is by the light socket, and the light looks like it should come out, but you never know.
Old 10-31-2013, 01:47 PM   #6
Iggy's Avatar
Have you checked to see if you have voltage at the socket with a volt meter?
Have you checked the switch in the door is not stuck in the door closed position?
Check the fuse in the back of the unit near the control board.
That's the best I can suggest at the moment.
Good luck
fridge, light
