bubbles gave you some good advice.
Also how are you plugging into your generator?
Do you have an adapter or does your shore power cord plug directly into the generator.
If using an adapter, maybe one leg is open.
Rigs with two A/C units run one A/C on one 50 amp leg and the second unit on the other 50 amp leg of your 4 prong shore cord. If everything works OK when plugged into shore power, something has to be amiss in feeding one of the legs from your generator.
