Old 05-21-2010, 04:37 AM   #1
front a/c not operating 357
Had my generator and front a/c on in my new 357QS. The generator cut out during first minute of start up . A/c kicked in then stopped. Re-started the generator turned a/c unit on ..nothing..check the breaker..nothing..can hear a click everytime i turn the fan on. The click is at the dash area.
Check rear a/c and works find..check all fuses ..all good..headin out this afternoon..hate to stopp at dealer if it is simple
Any suggestions?
ravenmike is offline   Reply With Quote
Old 05-21-2010, 08:16 AM   #2
ronhanson's Avatar
It's odd the click is coming from the dash area. I would think the front roof AC should be tied into the 110V breaker box only. Maybe someone else has more knowledge of this.
Hopefully your generator didn't go low voltage when it died and fry the AC.
Typically you should let the generator run for a few minutes and stabilize before putting any loads on it.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 05-21-2010, 01:16 PM   #3
Front air
When the air conditioner's cycle is interrupted the high pressure will prevent it from restarting right away. You have to wait until the pressure equalizes before starting it again; usuallly 15 to 2w0 minutes.
Crossfire is offline   Reply With Quote
Old 05-21-2010, 03:36 PM   #4
Found the issue ... breaker on Gen. ..Forgot about that one
Old 05-22-2010, 04:03 PM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
Great to hear it wasn't something serious. So now the rest of us can store this in the old memory banks in case it ever happens to us. Thanks for posting your find.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
