Old 07-24-2015, 05:12 AM   #1
BillMFl's Avatar
front ac
Does the entire plastic cover on the inside of ceiling snap off to access bolts or just the grill? I need to tighten the mounting bolts. Don't want to damage the inside cover.
BillMFl is offline   Reply With Quote
Old 07-24-2015, 05:19 AM   #2
mud yapster's Avatar
Both my Dometic have screws in the outside plastic panel. There is a couple plastic round things that cover up 2 of the screws then 2 more screws underneath where the air filter is. Remove air filter to get to those. Then you will see the mounting 4 bolts holding the unit to the coach. Hope that's not to confusing.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 07-24-2015, 03:45 PM   #3
BillMFl's Avatar
Clear as Mud. Thank you.
