Front AC won't cool like rear AC, dealer says it's normal
My 30x3 only came with 1 AC and it wouldn't keep the rig cool, so I added the exact same model to the bedroom after upgrading to 50 amp service. When we got to use them together this summer the front AC was running at least 15 degrees warmer than the rear unit. I used a infrared temperature gun to confirm the temp in the direct output vent. They were basically working against each other.
I have it at the dealer and they are saying front unit works fine and its normal for two units to be that far apart. In direct sun the two units still won't keep the RV cool.
You folks with two units, do yours run about the same temperature?
2017 Georgetown GT3 30x3
Mechanicsville, VA
