Originally Posted by rkulbok
Pretty much the same thing happened to me. Turned out to be a vacuum line had come off.
Not a blower not functioning but working and air only being sent to the defroster problem. The air handler switch controlling where the blower sends the air is actually a vacuum switch controlling diverter panels in the air handler system. In my case, the vacuum feed line under the hood had come disconnected which locked the system in defrost mode.
Another discovery I made is that when parked for the night when it's cold outside, the air handler should be set to "Max AC" which closes the outside vent. This helps keep the coach warm when you're using the furnace or other interior heating mechanisms.
Phil
