Old 04-15-2010, 03:25 PM   #1
Front end alignment
Picked up my new 2009 georgetown 373 a few weeks ago and as suggested I am taking it in for a front end alignment.
The only close place I could find mainly does large trucks.
Will they just know the setting to use for the motorhome?
Can anyone tell me what the settings should be?
Stuart Norman
snorman is offline   Reply With Quote
Old 04-15-2010, 04:19 PM   #2
NWJeeper's Avatar
Stuart Norman
Those numbers would be found in a shop manual for the F53 chassis which you would have to buy. Just like a car it isn't really important for you to know them since you don't have the equipment to measure anyway, only that the shop does. Shops that handle the big rigs will or should know what do to. I wouldn't worry about it.
Ed & Wendy
www.nwjeepn.com
Old 04-15-2010, 06:04 PM   #3
The place that did mine also a truck place, had a computer printout that they gave me after they aligned it. It showed the factory settings, the current settings, and the new corrected settings. Good for you to get it aligned. I found out after I noticed tire wear after a 4000 mile trip on my new 315 DS SE. It was off quite a bit new from the factory. Left front tire lost half its tread in 5000 miles The #'s should be in the computer or the equipment that they use to align it. I cannot imagine them using #'s they pull out of thin air. An F53 chassis is pretty common.
2008 Georgetown 315DS SE
khager is offline   Reply With Quote
Old 04-15-2010, 06:46 PM   #4
kvtaylor's Avatar
Ford Truck in Richmond did mine. It was done when it was new and I have had no problems with the stearing since we bought it. it has 19,000 on it now and the tires are running true.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 04-15-2010, 08:18 PM   #5
Thanks everyone.
Old 04-16-2010, 08:17 AM   #6
ronhanson's Avatar
There are advocates on other forums out there that insist the caster be set to 4.5 degrees or more on an F53 which will help stability. I have no idea what factory specs are but it might be worth talking to an expert about.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 04-16-2010, 10:30 AM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
Just had my front end alignment checked when I had the shim removed. The repair center found it towed 1/32" in, which is within factory specs. I haven't noticed any wear on the front tires. I guess they did it prior to it leaving the factory.
Best part FR paid for it as well as having the shim removed.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is offline   Reply With Quote
Old 04-16-2010, 12:24 PM   #8
Just back from the alignment.
Just the caster on the right tire was a little high. (5.7)
Everything else was within the min/max allowed values.
Now
Castor 0.6
Camber 4.9
Toe in 0.02"
2009 Georgetown 373f
2000 Honda CRV
Old 04-16-2010, 12:25 PM   #9
Oops should be
Camber 0.6
Caster 4.9
2000 Honda CRV
alignment
