Old 07-23-2013, 06:48 PM   #11
Fulltime family RVer
Changed.
Old 07-23-2013, 06:49 PM   #12
Newellri's Avatar
Thanks!
Newellri is offline   Reply With Quote
Old 07-23-2013, 07:23 PM   #13
Your shade is made by MCD Shades. Go to their website and you will find a drop down menue for your shade. You can download the manual and it gives detailed instructions on adjusting your shade. It is easy, first locate the hanging wire with a button on the end, which is located on the left side of the shade near the roller tube.
Refer to the instructions in the manual to adjust.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 07-23-2013, 07:24 PM   #14
TURBS's Avatar
I knew someone would know!
Old 07-23-2013, 08:00 PM   #15
Newellri's Avatar
Thanks to all ! I knew someone would know!
Old 07-23-2013, 08:26 PM   #16
Iggy's Avatar
Originally Posted by Newellri View Post
Attachment 36045. This is a pic sorry no label on the front. The front screen used to go up higher, now it stop in this position. Hope this helps. There must be some kind of stop on it but where?
Here is the manual for my front power window shade.
There is a programming switch hidden in the left side column that you must use to reset the memory or the shade controls.
File Type: pdf Privacy Shade Programming Instructions.pdf (92.2 KB, 73 views)
Iggy is online now   Reply With Quote
Old 07-24-2013, 08:11 PM   #17
Newellri's Avatar
Thanks to everyone ----- got it set this afternoon while it was a little cooler --- works now!
Old 08-09-2013, 07:21 PM   #18
intercept's Avatar
Hi Iggy,
The manual is not on this post ,,,, can u send to me.
Thanks,
John
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
Old 08-09-2013, 10:16 PM   #19
10Isola
My front shade seems to be off kilter - possibly from it being parked on an angle where it is stored. The one side of the shade binds up from too much overhang, and prevents smooth operation. It sometimes jams the operation. I have not found this in any of the manuals on how to fix. It would be ideal if I was able to detach the whole role, rewind manually and start over newly aligned. Any input or help on this would be appreciated. Thanks so much.
Georgetown 320DS
10Isola is offline   Reply With Quote
Old 08-09-2013, 11:46 PM   #20
Newellri's Avatar
This is a new one....today while driving down the hi way the front shade just started coming down! Now the memory has been lost again! Grrrr
