07-23-2013, 03:43 PM
Front interior sun shade doesn't fully retract
Need information on the front awning --- is there an adjustment on the upper limit ours doesn't seem to be going all the way up. Don't want to get caught in a camp ground and not get it up, to leave.
07-23-2013, 04:00 PM
Make and model of awning would help.
Pictures are also worth a 1000 words.
Turbs
07-23-2013, 04:05 PM
Thanks will check it out......fellow Iowan
07-23-2013, 04:12 PM
Were u located?
07-23-2013, 04:35 PM
. This is a pic sorry no label on the front. The front screen used to go up higher, now it stop in this position. Hope this helps. There must be some kind of stop on it but where?
07-23-2013, 04:36 PM
Ankeny, retired tool and die maker.
07-23-2013, 06:21 PM
Hmmmm ok lol I thought you were talking front outside awning !
I guess a more better term would be front interior sun shade.
Maybe a mod can fix the heading for you so other may know of the issue.
We live east of cedar rapids 38 miles.
Turbs
07-23-2013, 06:31 PM
Thanks.....my DW informed it was a poor choice of nomenclature, guess she was right. Bummer. It would seem it must have a stop somewhere.
07-23-2013, 06:34 PM
I have a small farm in the muscatine area and still go down there to mow and clean up even though I don't farm it anymore.
07-23-2013, 06:46 PM
30 minutes south.
Sweet!
07-23-2013, 06:48 PM
Always Learning
Changed.
07-23-2013, 06:49 PM
Thanks!
07-23-2013, 07:23 PM
Your shade is made by MCD Shades. Go to their website and you will find a drop down menue for your shade. You can download the manual and it gives detailed instructions on adjusting your shade. It is easy, first locate the hanging wire with a button on the end, which is located on the left side of the shade near the roller tube.
Refer to the instructions in the manual to adjust.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
07-23-2013, 07:24 PM
I knew someone would know!
07-23-2013, 08:00 PM
Thanks to all ! I knew someone would know!
07-23-2013, 08:26 PM
Attachment 36045. This is a pic sorry no label on the front. The front screen used to go up higher, now it stop in this position. Hope this helps. There must be some kind of stop on it but where?
Here is the manual for my front power window shade.
There is a programming switch hidden in the left side column that you must use to reset the memory or the shade controls.
07-24-2013, 08:11 PM
Thanks to everyone ----- got it set this afternoon while it was a little cooler --- works now!
08-09-2013, 07:21 PM
Hi Iggy,
The manual is not on this post ,,,, can u send to me.
Thanks,
John
2012 Georgetown 378XL
Toad 07 Lexus RX350
08-09-2013, 10:16 PM
10Isola
My front shade seems to be off kilter - possibly from it being parked on an angle where it is stored. The one side of the shade binds up from too much overhang, and prevents smooth operation. It sometimes jams the operation. I have not found this in any of the manuals on how to fix. It would be ideal if I was able to detach the whole role, rewind manually and start over newly aligned. Any input or help on this would be appreciated. Thanks so much.
Georgetown 320DS
08-09-2013, 11:46 PM
This is a new one....today while driving down the hi way the front shade just started coming down! Now the memory has been lost again! Grrrr
