Old 08-02-2015, 03:16 PM   #1
Front led some lights and king jack air have no power
I have a brand new 364ts. We stayed overnight in it for the first time last night. When I woke up this morning all three of the front overhead dome lights didn't work and there is no power to the king jack air antenna. Everything else works. All four of these fixtures are aligned down the mid line of the RV. I've check fuses above the rear bed and all are good. Any ideas?
cousin eddie johnson is offline   Reply With Quote
Old 08-02-2015, 08:37 PM   #2
abjb's Avatar
12v fuses are located in several places,
with the 110v breakers
under the dash to the left of the steering wheel
under the hood
and under the steps
Here are some link that will help you locate the fuses.
post #2 Dash A/C, mounted Fans, Back up Monitor Not Working
again post #2, mentions the antenna booster Antenna Boost/Amp Fuse Location
I used the advanced search feature looking for "fuse"
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
led, light, power
