Old 07-03-2012, 08:39 PM   #1
Front shade settings
Originally Posted by Iggy View Post
Lostdog I just switched off 5.1 and changed to stereo.
It works much much better and no echo.
Thank you very much and hope others with similiar issue now have a solution.
Iggy
Your welcome, Iggy. Now.....does anybody else have problems with the front shade settings staying set? Ours has a mind of it's own.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 07-03-2012, 09:14 PM   #2
Iggy's Avatar
Good question. My dealer said they adjusted mine and it works fine.
It only goes down a specific amount while the rig is running and moving.
Not sure how they adjusted but would also liek to know how to do it just in case something goes wrong like yours.
You might want to start a new questions about it.
Iggy is online now   Reply With Quote
Old 07-03-2012, 10:11 PM   #3
Iggy's Avatar
Here is setup manual for my front windows sunscreen adjustment.
The important setup is to get in memory mode and setup all 4 setmarks.
2 with ignition on limits then you must do the 2 with the ignition off mode.
Hope it helps
Old 07-04-2012, 01:27 PM   #4
Hope it helps
Yup, got it. Have reset the limits, per the manual, at least a dozen times. It simply does what it wants to.
I'm going to start another thread and see if anybody has had the same problems.
Lostdog
Old 07-06-2012, 10:09 PM   #5
VinceU's Avatar
Have you called MCD to see if they recognize the symptoms? Realize its out of 1 year warranty but maybe they'll help.
Old 08-04-2012, 10:27 PM   #6
copsuno's Avatar
My shade just got out of sync and the right (passenger) side is chewing up the edge of shade. Any suggestions how to correct this?
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 08-05-2012, 08:33 AM   #7
VinceU's Avatar
Very detailed directions from mfg on line.
Old 08-21-2012, 05:27 AM   #8
I suggest you take down the shade and manually re-roll it straight or make sure its in the track when rolling back up.. mine was doing this an now I have ordered a new motor the wires got chewed up on drivers side.
Joeprinter is offline   Reply With Quote
Old 08-21-2012, 05:36 AM   #9
copsuno's Avatar
Thanks for reply, my dealer, Adventure Motorhomes, has been fantastic and found that the screws that hold the passenger side up were loose and that caused the problem. Unfortunately since shade was out of warranty no new shade, just repaired free though.
