Originally Posted by Juju
Ok, we are in a real pickle now. Front slider will not move......out or in. HELP!!!!!
OUCH the same thing happened to us, slide was out.
Is your pump running, are you on shore or generator power?
Take a look at your slide to make sure it's ALL THE WAY in or out,
both ends.
One of our hydraulic rams was not moving as fast as the other (the one under the refrigerator).
Causing the slide to wedge itself after moving about 18" in the front and only 6" in the back.
I adjusted the slide enough with the
ram adjusters to get the slide UNwedged
Then I got a come-a long like this one
1200 Lb. Capacity Cable Puller
and 2 long tow ropes.
Tied one rope to the front ram bracket the other to a tree (
my tree, almost pulled it out of the ground) with the come-a-long in between.
Held the front ram while the back one caught up.
Had to let some slack in the come-a-long several times!
Our dealer and I were hopping the problem was in the splitter valve between the 2 rams $$$ it wasn't.
Hind sight 20/20 should have had the rams rebuilt $$$, dealer replaced both rams $,$$$.
