Old 07-27-2017, 06:54 PM   #1
Fundamental question about CHF.
I admit that I haven't read every single post about the CHF, so I may have missed this question being asked and answered. Also, I am not doubting the comments from so many of you that this fix significantly improves handling.
Having said all that, here's my question:
If this fix is so beneficial and even improves safety, why doesn't Forest River do this at the factory?
Gloryhog is offline   Reply With Quote
Old 07-27-2017, 06:58 PM   #2
RSchleder's Avatar
I can do you one better, I haven't read even 1 post about "the CHF"! Perhaps you could enlighten those of us that are uniformed and not in the "loop" on this 3 letter mystery subject.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-27-2017, 07:08 PM   #3
Wobbles's Avatar
Cheap Handling Fix. May be forum specific as in this product... Just my WAG.
Safe Travels.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 07-27-2017, 07:29 PM   #4
Citrus County, Fl.
GL1800Rider's Avatar
I always thought CHF was Congestive Heart Failure
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-27-2017, 08:35 PM   #5
A32Deuce's Avatar
CHF is adjusting the front sway bar tighter.
A32Deuce is offline   Reply With Quote
Old 07-28-2017, 01:46 AM   #6
Because it's a "hack" and not a properly engineered solution. While it reduces body roll, it can also negatively affect some other aspects. I doubt any of the proponents of the CHF have tested their vehicle like Ford does during development:
TheGerman is offline   Reply With Quote
Old 07-28-2017, 04:15 AM   #7
Oaklevel's Avatar
Thanks I was wondering what a CHF was as well.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-28-2017, 06:41 AM   #8
Instead of buying factory steering control or factor trackbars,they make their
own. I personally would not drive a MH without a saf t plus or a track bar on the
rear axle. It settles the drive down and makes it a pleasure to drive.
That's my opinion.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 07-28-2017, 06:59 AM   #9
waiter21's Avatar
CHF - Cheap Handling Fix...
Ford F53 chassis comes with two adjustment points on the front and rear torsion bars. When it leaves the Ford factory, the attach links (adjustment) are mounted on the front (loose) positions. The CHF is re-positioning the links to the rear (firm) position. No magic, no hacks, simply a chassis adjustment.
Why doesn't Forest River do this? Ask FR.
I've done the CHF on both of the F53 chassis that I've owned and will do it to any future F53 chassis that I buy. Its a simple adjustment that has significant impact on improving the driveability and handling of the F53.
Cheap Handling Fix – and then some – 2001 Coachmen Mirada 300QB
I'd recommend anyone doing this to extend the front links (see the article on how to do this)
IMHO - Before spending any money on aftermarket suspension components, do the CHF first, then re-evaluate how it handles.
Also verify the front end Toe adjustment. This is easy to check and do.
http://www.1999southwind.com/f53-cha...in-adjustment/
IMPORTANT - On 2006 and newer, Ford changed the rear torsion bar / axle attach point brackets (the bracket where the torsion bar attaches to the rear axle). The bolts have a habit of loosening and falling out. Remove the four bolts, and re-install them with blue locktite then torque to 65 ft lbs.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-28-2017, 07:25 AM   #10
AquaMan's Avatar
My question on the CHF for anyone that has done this, have you noticed that your wheels come off the ground quicker during leveling?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-28-2017, 08:00 AM   #11
360true's Avatar
Yes if I use auto leveler, my front wheels often will b be lifted because the wheels are now tighter to the chassis. So I level manually and rarely if ever do my wheels lift.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 07-28-2017, 08:33 AM   #12
Back On The Go
Here's a link to the place I first read about CHF. The thread started 7/28/2010 and is still going strong. Everything you could possibly want to know is probably in these comments. Beware, you may get stuck reading this for longer than you really want to.
Cheap Handling Fix - iRV2 Forums
2016 Georgetown 270S
2013 Ford C-Max Hybrid
2 Jamis Hybrid Bicycles
Not too serious about anything except what affects health and happiness.
salwolfe is offline   Reply With Quote
Old 07-28-2017, 02:38 PM   #13
waiter21's Avatar
Aquaman;
I'd say that if you did not extend the front links, its possible you could be lifting the front axle by the links,
Take a look at the drawings I did regarding the "As Built", "Standard CHF" and "Extended strut CHF" in the article. These where scale drawings in Autocad.
Note that these are for a 2001 chassis, newer F53 are similar, I think some F53 came with a link that is 1 inch longer.
I extended my links to get the better angles to the torsion bar, mine doesn't lift the front axle by the links,
