01-20-2012, 07:48 AM
Furnace and electricity?
We are working out of our 2004 (new to us) Georgetown and last night in frigid conditions, our furnace shut off in the middle of the night. This morning I had to turn on the engine in order to start the generator and then start the furnace. I guess I have 2 problems, the generator is not starting on its own (without turning on the engine) and the furnace is not working without any power. I do know that the two coach batteries are new when we purchased it in October. Am I doing something wrong? I'm pretty sure I don't have anything but the phone charger connected to the engine battery overnight.
Thanks for any help!
01-20-2012, 02:14 PM
Furnace will pull lot of juice from house batteries, ergo gen did not have enough juice to crank without alt power from engine. You did not say if you were hooked to shore power or dry camping. I you do not have good insulation and dual pane windows, furnace runs longer and sucks batteries quickly.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 42yrs, and 2001 Saturn toad, what more could you ask for.
01-20-2012, 05:09 PM
Also, check that you have more than 1/4 fuel in your tank. The furnace is designed to shut off when the chassis tank is at or lower than 1/4 tank. If you were hooked up to 30/50 amp electric service you should have had enough power to run it but I'm guessing you must have been dry camping?
I had following problem with my generator. My brushes were worn. It too would not start on it's own but after I replaced the brushes, I've not had any further problems. The brushes were not hard to replace, if that's what it ends up being. Save your self some major bucks and pull the brushes before taking to a service center.
Good luck.
Camping 2012 (5)
01-20-2012, 05:44 PM
Good luck.
The Generator not the Furnace will shut off when your Gas Tank gets below 1/4 Tank.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
01-20-2012, 05:48 PM
Are you sure the Coach Disconnect Switch wasn't clicked off? If so the furnace will run until the batteries draw down and then shut off. The Generator won't crank very much to start and if the generator did start the batteries would not charge with the switch in the off position. Just push the top of the switch to engage the circuit. The switch stays lit whether it's On or Off so it can be found in the dark. You may need to run the engine to charge the batteries quicker than the Generator.
 to the forums!!
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
01-21-2012, 04:16 PM
MY bad, for some reason I was thinking he was running the generator and it stopped along with the furnace.
Camping 2012 (5)
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 297 |
| 15 members and 282 guests |
| 1l243, bama gail, brookside, ChiefGeek, Greene, HondoPatrick, House97, Mountainmanbob, Namchief, nrcamp, onthelake, Rebel702, Rsgtivr6, shooted, sprayking |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
