Old 01-20-2013, 10:49 AM   #1
Furnace question
325S MODEL M/H, Suburban SF35 f furnace. Can the furnace be switched to have the blower motor run on demand?
trell is offline   Reply With Quote
Old 01-20-2013, 11:13 AM   #2
Witch Doctor's Avatar
The SHORT answer is yes, either do it with a relay or you will need a separate switch. Also they make a fan center that could be used just as you furnace at home using the same stat..
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 01-20-2013, 12:38 PM   #3
Thinking same thing
would you know more about fan board that you could share?
