Old 11-23-2013, 03:01 PM   #11
Ford Idaho's Avatar
Originally Posted by rockfordroo View Post
When I bought my Roo last year, it was doing the same thing. The furnace would fire up the first time, but then not again unless the thermostat was toggled. What seems odd is that there are only 2 wires that are connected together when the switch in the thermostat closes to start the furnace and when the wires are disconnected, it turns the furnace off. What could be simpler? Anyway, I replaced the chintzy Suburban thermostat with a Honeywell RTH111 digital and it's worked fine ever since. I can't explain it, except maybe dirty contacts don't allow enough current to flow when the switch closes.
When I first joined here there was a series of threads about replacing bad thermostats, could this be a recurrence?
Old 11-23-2013, 09:29 PM   #12
Fulltime family RVer
Originally Posted by Iwannacamp View Post
The suburban install manual says no screens. Of at least the one I have says so. I personally cannot see where this could ever cause a problem.
I agree- but if I were having a problem with something, the first thing that I would do is flip through the book and see what kinds of things that they recommend against that I'm possibly doing. If it takes all of 45 seconds to remove a couple of screens, why not?
Old 11-24-2013, 06:10 AM   #13
mduff's Avatar
We had a similar experience and replaced the chintzy thermostat. We found that by tapping the thermostat it would cause the furnace to work; suspect similar to toggling...
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 11-24-2013, 06:18 AM   #14
Agree to a certain point, but the open style screens (that are sold by the thousands) could prevent a furnace from staying lighted defies logic. They are a very open mesh.
New Mud Dauber Furnace Screen for RV camper motorhome 5th Wheel M 300 | eBay
As I posted before, would like to see some actual hard data supporting this statement in the manuals.
Old 11-24-2013, 06:46 AM   #15
rattleNsmoke's Avatar
Agree 100% Coot. I would think the Dauber's could and would far more damage than a wire mesh screen.
rattleNsmoke is offline   Reply With Quote
Old 11-24-2013, 08:46 AM   #16
You're both missing what I'm suggesting- I think that it's a temporary test to see if this is the or part of the problem. If it fixes the issue, then debate putting then back on. If it doesn't fix the issue, you're only out a few minutes of time and effort.
Old 11-24-2013, 08:54 AM   #17
Not at all, it's just such a ridiculous statement saying a screen on the outside of the camper will influence the burner/gas valve functioning properly.
Old 11-24-2013, 08:59 AM   #18
Given that our answer is "RTFM" for so many other things - so I don't know why we would instantly demand "more data" for this one. Suburban wouldn't just randomly add something to their manual, IMO.
As well, I don't think we should instantly dismiss it just because it worked for you for your 130 years of camping.
Old 11-24-2013, 09:04 AM   #19
fonzie's Avatar
A screen added to the outside intake/exhaust of the furnace that is designed for it will most likely have little effect on air flow. Add enough contamination to it (dirt, grease lint etc etc) to it and it might reduce air flow enough to affect the sail switch from closing or the over temperature disk in the burner section might open, thus a malfunctinning furnace....
Fonzie
Old 11-24-2013, 09:07 AM   #20
Doug, just stop and think about what they are stating that a pc of screen wire on the outside of the trailer causes a malfunction in an electrically energized gas valve inside the furnace. It defies logic and common sense. Just because Suburban published it doesn't make it fact. Like "it's on the internet, so it has to be true."
furnace
