Old 03-07-2016, 06:08 PM   #11
SS396CV's Avatar
The 378 has 2, 1 under the stove, another under the sink. The kitchen is L shaped. The sink furnace heats the rear section/bedroom of the coach
2014 Forest River Georgetown XL 378TS
SS396CV is offline   Reply With Quote
Old 03-07-2016, 06:21 PM   #12
SS396CV's Avatar
The 352 XL, 377 XL and 378 XL have 2 furnaces
Old 03-07-2016, 06:22 PM   #13
bubbles's Avatar
The aft furnace heats the entire coach through the floor registers. The aft furnace is the only one that uses the floor registers.
Old 03-07-2016, 06:43 PM   #14
SS396CV's Avatar
I just assumed the front one was the main one, you know what they say about assumptions, LOL. I see the front only runs 2 registers. Good to know.
Old 03-15-2016, 03:53 PM   #15
My question is we have propane and it is on. We were having a problem with the hot water heater but that seems to working. Now we have no heat to the furnace and the stove is not lighting. I don't even smell gas when I try to light it. Any thoughts?
sdowning is offline   Reply With Quote
Old 03-16-2016, 01:31 AM   #16
ramair's Avatar
If you have propane and there is no flow to stove check the co detector if it is tripped then it will shut off the flow of propane. Must have 12v going to the switch. To check look at the propane tank and on the hose going to the MH there is a switch and it should be hot. If its cold then check the fuse to the detector. Hope this helps.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 03-16-2016, 08:26 AM   #17
abjb's Avatar
A quick note about the safety switch.
Its NORMAL condition is on, and HOT (very hot) be careful when you touch it!
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
furnace
