Old 09-14-2016, 06:53 PM   #1
Fuse box question
This is kind of a dumb question, but does anyone know how to remove the black cover over the under dash fuse panel? My radio and acc outlet stopped working this morning, and I suspect the fuse, which I think is in the under dash group.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
ohiobill is offline   Reply With Quote
Old 09-14-2016, 10:26 PM   #2
Iggy's Avatar
Just pull the black over off.
It's only held on by some plastic clips.
Don't be scared to pull it. It won't break.
Pull the two tabs next to the arrows.
ID:	120249   Click image for larger version
2012 Georgetown XL - 378TS
Old 09-15-2016, 08:10 AM   #3
Thanks Iggy, that did it. Didn't want to break it. Not the easiest place to get to!
Old 09-15-2016, 08:20 AM   #4
chrisbailey13's Avatar
Interesting....My unit didn't even come with a black cover.
2014 Georgetown XL 352QS
2013-2017 Days Camped-170
chrisbailey13 is offline   Reply With Quote
Old 01-10-2017, 04:11 PM   #5
I also have a problem with the radio and accesories plugs not working on my 2007 Georgetown 359XL. My Ford manual does not show where the fuse is, can anyone help.
Hankster is offline   Reply With Quote
Old 01-11-2017, 12:04 AM   #6
I have 2007 340. Mine is under dash near gas peddle
Vegasmailman is offline   Reply With Quote
Old 01-11-2017, 08:25 AM   #7
bubbles's Avatar
If memory serves me, you squeeze the two tabs together with finger and thumb to release it from the panel. Comes right off easily.
Old 01-11-2017, 11:09 AM   #8
One more question, does anyones manual show which fuse it is. My manual doesn't show it. I have the 2007 359XL TS. Still running good and still happy with it.
Old 01-15-2017, 08:21 PM   #9
Have the same problem with my 2013 378XL. Radio will not come on, suspect fuse.
2013 Georgetown XL 378TS
bobbie2 is offline   Reply With Quote
Old 01-25-2017, 01:45 PM   #10
I have checked the fuses under the dash, drivers side, and they are fine. I also checked the fuses under the hood, no problem there. Does anyone know if there is another fuse that controls power to the radio and the accessory plugs? I'm baffled.
Hank, 2007 Georgetown LX 359 TS - waiting for warm weather in Yuma.
fuse
