Old 05-13-2010, 01:18 PM   #1
Fuse for Arctic Pak
We have a 2003 30' georgetown mh.
We also have arctic pak which thermostatically heats the black and grey water tanks.
The light in the switch was not lighting up when turned on.
From others and FR I thought the switch was faulty. So I replaced the switch and it still didn't light up.
I tested the wires coming to the switch and there is no voltage to any of them.
So I am assuming a fuse must be tripped.
I called FR and they couldn't tell me where the fuse for it was, but didn't think it was an inline fuse.
Does anyone know where the fuse for this arctic pak is ??
rdjensen is offline   Reply With Quote
Old 05-18-2010, 06:14 PM   #2
This is a typical answer from FR.Is this the way to run a business?
franbourget is offline   Reply With Quote
Old 05-18-2010, 07:31 PM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
I thought it would be in the fuse and breaker box, which in my case is just below the switch, but I didn't see anything labeled Arctic Pak. Unless it's on with another item labeled I don't know. I'd have to turn on the switch and start pulling fuses. If I get a chance I'll try it this weekend.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 05-18-2010, 09:45 PM   #4
milzat's Avatar
I'm not saying this is where yours is, but on my last trailer, the fuse was located behind the shower/garden tub skirting.
The shower/garden tub base had removable panels. The fuse was located behind these panels, near where the wiring goes through a hole in the floor.
Looks to me that all fuses could be placed in a central location. It only makes good sense.
milzat is offline   Reply With Quote
Old 05-19-2010, 02:39 PM   #5
Arctic Pak Fuse
I found the fuse.
It was in the main breaker/fuse box in the back of the motorhome.
